Part has holes
All  1-3  4-5
6747.4 In reply to 6747.1
Yeah it's probably those little surface fragments that Marco shows above.
Try this version, here I've removed those little tiny slivery pieces, hopefully it should generate a better mesh.
I exported an STL with it with Angle = 5, and Divide larger than = 1 applied to "All" and it doesn't seem to have any problems in it anymore.
I wish I knew which particular step was getting those little tiny fragments to be produced in the first place, I'd like for that not to happen...
6747.5 In reply to 6747.4
I don't remember exactly how I did that. I know I couldn't loft the tapered end and I don't think I used a sweep. I think used a revolve and then extruded the flange and then did a difference to put the hole in the flange and then did a combine ....
Thanks for your help guys ....
bz
Show messages: All  1-3  4-5
