Part has holes
6747.1
I submitted this part for a 3D print quote and it kicked it back saying that the part has holes.
I know that there is a way to trouble shoot this but I haven't a clue ...
Any help would to most helpful.
6747.2
Hello,
You could use the SelectNakedEdges script found here:
http://kyticka.webzdarma.cz/3d/moi/
It looks like that part is watertight.
6747.3 In reply to 6747.2
actually, i've spotted some isolated surfaces. tinytiny surfaces..
and Meshmixer indicates them as mesh defects(blue=hole, red=non-manifold):
EDITED: 3 Jun 2014 by MARCO
6747.4 In reply to 6747.1
Yeah it's probably those little surface fragments that Marco shows above.
Try this version, here I've removed those little tiny slivery pieces, hopefully it should generate a better mesh.
I exported an STL with it with Angle = 5, and Divide larger than = 1 applied to "All" and it doesn't seem to have any problems in it anymore.
I wish I knew which particular step was getting those little tiny fragments to be produced in the first place, I'd like for that not to happen...
6747.5 In reply to 6747.4
I don't remember exactly how I did that. I know I couldn't loft the tapered end and I don't think I used a sweep. I think used a revolve and then extruded the flange and then did a difference to put the hole in the flange and then did a combine ....
Thanks for your help guys ....
bz
