Flow command Tutorials
All  1-13  14-19
6746.14
The flow command is totally awesome!
Making swoopy sweeps is butter smooth.
Dries
6746.15 In reply to 6746.14
Cool render and form!
6746.16 In reply to 6746.15
Hi all
I came across a flow problem that I think is related to my lack of understanding :)
My wife asked me if I could convert a flat tree of life pendant I designed for her into a half ball
Naturally I said no problem I'll just flow it onto half sphere using surfac flow
Boy was I wrong :) I get all sorts of messed up surfaces has the flow reaches the edge of the half sphere
I'm on the train now so can't post files/images :)
Cheers stephen
6746.17 In reply to 6746.16
Hi Steve, I may need to see your actual file or some screenshots later on in order to really give you a proper suggestion.
It's possible that you may want to make a different kind of surface than a regular sphere as the target object though - a regular sphere in MoI is a surface that squishes down into a "pole" area at the top and bottom, and things that you flow will also get squished in those same areas where the surface is collapsing down to a single point too. The deformation follows the surface structure basically.
You may need to build a custom sort of "cup" like surface using Sweep instead of using the regular default sphere-with-pole surface. Something like this I mean:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1782.4
Also if you want the deformation to work more like it's dropping down to a local area of the sphere rather than wrapping across the entire surface, there is a "projective" mode for surface-to-surface flow that can work better for that, but you would use it for getting just some curvature onto the end result not a major amount like going to a half ball. Some examples of projective mode here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5936.2
6746.18
Hmmm
Here is a screen shot of what I was getting the other night...
But tonight I'm not getting these bad surfaces.... but I deleted yesterdays file and started again now I can replicate the problem..... I must have done something wrong.....
6746.19 In reply to 6746.18
Hi Steve, it can cause problems if you're using a sphere for the target surface and have objects that are right at that "pole" area where the sphere collapses down to a single point.
That might possibly be the problem... If it's not that I'd need to see a 3DM file with your objects in them in order to give you some better feedback on what's going on there.
Show messages: All  1-13  14-19
