Flow command Tutorials
All  1-12  13-19
6746.13
Well my last post on the test images for now, don't want to use all the forum space up.
6746.14
The flow command is totally awesome!
Making swoopy sweeps is butter smooth.
Dries
6746.15 In reply to 6746.14
Cool render and form!
6746.16 In reply to 6746.15
Hi all
I came across a flow problem that I think is related to my lack of understanding :)
My wife asked me if I could convert a flat tree of life pendant I designed for her into a half ball
Naturally I said no problem I'll just flow it onto half sphere using surfac flow
Boy was I wrong :) I get all sorts of messed up surfaces has the flow reaches the edge of the half sphere
I'm on the train now so can't post files/images :)
Cheers stephen
6746.17 In reply to 6746.16
Hi Steve, I may need to see your actual file or some screenshots later on in order to really give you a proper suggestion.
It's possible that you may want to make a different kind of surface than a regular sphere as the target object though - a regular sphere in MoI is a surface that squishes down into a "pole" area at the top and bottom, and things that you flow will also get squished in those same areas where the surface is collapsing down to a single point too. The deformation follows the surface structure basically.
You may need to build a custom sort of "cup" like surface using Sweep instead of using the regular default sphere-with-pole surface. Something like this I mean:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1782.4
Also if you want the deformation to work more like it's dropping down to a local area of the sphere rather than wrapping across the entire surface, there is a "projective" mode for surface-to-surface flow that can work better for that, but you would use it for getting just some curvature onto the end result not a major amount like going to a half ball. Some examples of projective mode here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5936.2
6746.18
Hmmm
Here is a screen shot of what I was getting the other night...
But tonight I'm not getting these bad surfaces.... but I deleted yesterdays file and started again now I can replicate the problem..... I must have done something wrong.....
6746.19 In reply to 6746.18
Hi Steve, it can cause problems if you're using a sphere for the target surface and have objects that are right at that "pole" area where the sphere collapses down to a single point.
That might possibly be the problem... If it's not that I'd need to see a 3DM file with your objects in them in order to give you some better feedback on what's going on there.
Show messages: All  1-12  13-19
