Complex 3dm model downloads to MoI usability on tablet?
All  1  2-4
6735.2 In reply to 6735.1
Hi Sven, probably your best bet is http://grabcad.com
6735.3 In reply to 6735.1
You could also just use simple objects and array.
Make a line and array 50, then array that 50, then array that 50. Pretty quick to have 125,000 curves which is pretty heavy.
Same thing with a simple sphere.
6735.4 In reply to 6735.1
Hi Sven, also if you're going to be working with heavy models it's a good idea to adjust some display settings in MoI.
Go to Options > View > Meshing parameters and change the "Mesh angle" setting to a rougher angle like 25 or 30 degrees instead of the default 10 degrees, and uncheck "Add details to inflections".
That will make for a slightly rougher looking shaded display but it will also considerably reduce the density of the display mesh and will help make complex models perform better.
Show messages: All  1  2-4
