General Scripting Question
6727.1
Hi there,
is it really necessary to restart moi to test out a change in a custom script?
There must be a trick.....
Ralf
6727.2 In reply to 6727.1
Hi Ralf, by default when MoI loads a text file from disk, it caches it in memory so the next time it's accessed it doesn't have to be read in again.
You can disable that caching though by a setting in moi.ini under:
[UI]
DisableFileCaching=y
If you set that, that should be more convenient for script development.
6727.3 In reply to 6727.2
Wow, I thought there will be a trick..
Thanks a lot
