ornaments - looking for an advice
 1-17  18-22
6713.18 In reply to 6713.17
Is there a valid cheaper alternative ?
If there is , of course.
6713.19 In reply to 6713.18
Blender or Sculptris are free! ;)
http://www.blender.org/
http://pixologic.com/sculptris/
6713.20 In reply to 6713.18
Also 3D-Coat has a similar type of displacement brush stroke type approach.
http://3d-coat.com/
6713.21 In reply to 6713.16
Producing these ornamental designs as polygon models can be more time efficient, and give you a more fluid result, than what you would get with nurbs.
One advantage of using nurbs in this situation is if you wanted to reuse the models at a variety of sizes.
If you model in polys and discover later that you need to reproduce your model much larger, you would then have to increase the number of polys in your model so you don't see them in the finished part. While this can be done fairly quickly and with good results in many poly modeling applications, at some point the size increase might require rebuilding the model.
Another advantage of nurbs is that boolean functions like joining or subtraction typically don't cause issues for 3d printing. However, these functions can break solids in a poly modeler, so they might need to be repaired in a specialized program so they can be printed successfully.
6713.22
Hi matur61,
Here's a video by a friend showing how he went about making a fleur-de-lis using Rhino.
Although your design is much more complicated, hopefully this video will be of some use.
http://www.youtube.com/watch?v=qv6Sui8SR78
regards Colin
Show messages:  1-17  18-22
