help
6711.1
How can I bend this object 360 degrees to form a ring?
Size: 100.4 KB, Downloaded: 69 times, Dimensions: 1182x656px
6711.2 In reply to 6711.1
Of course yes!
Use the Flow function! ;)
Look at the Tire!
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5470.1
6711.3 In reply to 6711.1
Hi Mike, yes like Pilou says you can use the Transform > Deform > Flow command for that. Make sure you're running the v3 beta version since Flow is new for v3.
The way Flow works is it warps a shape from a base curve to a target curve (or from a base surface to target surface), so you'll need to draw a line running down the length of your object, that will be the base curve. Then draw a circle to use as the target curve.
Check out here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.246
http://moi3d.com/forum/index.php?webtag=MOI&msg=5097.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=5130.5
