New Jun-12-2007 beta available now.
 1-12  13-32  33-36
670.33 In reply to 670.31
Hmmm... Actually, I have also tried MSWord's drawing tools, but it failed as well... It looks like the pdf driver could cause the trouble. I use Adobe Acrobat 5.0 Standard Edition. -Petr
670.34 In reply to 670.28
Hi Petr, can you please send me a couple of the PDFs that don't work? (David posted one that does work)
I had tested this with .ai files saved from Illustrator CS that were set as "PDF compatible". I assumed that PDFs would also follow this same structure, maybe something is slightly different.
PDF is a pretty difficult format to support well, it's structure is pretty complex. It will probably take some tuning for it to work better.
670.35
Hello:
This is a file created with MSWord and converted with ALLPDF (you can try to convert online here https://www.pdfonline.com/convert_pdf.asp)
Bye!
670.36 In reply to 670.34
Hi Petr, I tried some more PDFs over here and I fixed up some bugs. I think it should be working a lot better now.
I put up a patch here: http://moi3d.com/beta/pdf_ai_patch.zip . If you download that, it contains a new moi_lib.dll file, just copy it over top of the one from the last beta and PDF import should be working better for you. Please let me know when you get a chance to try it next week. Thanks!
Show messages:  1-12  13-32  33-36
