Curve from two surface intersection
All  1  2-6
6698.2 In reply to 6698.1
It looks to me like the "helicoid" surface is not nice and smooth, but rather wrinkled?
6698.3 In reply to 6698.1
Hi Sharif,
> Do you have any idea what is casing this?
It appears to be happening because one of the surfaces has little bumps and waves in that same area. So the intersection curve is just following the shape of the surface there.
You can see the bumps a bit more easily if you hide the green object:
6698.4 In reply to 6698.3
Hi Michael;
The orange surface created by sweep a straight line along a curve. I noticed that when I set the sweep option twist to flat I get the bump/wave at top and bottom of the surface. If the sweep option set to freeform the resulting surface is perfectly smooth. Is there any solution to this?
-sjharif
6698.5
Hello,
You could try the Network command instead, it gives a better result. I used Network, Mode Uniform, Point Count 5 and it gave a very nice result. if you needed to trim that screw it also trims cleanly, no wobble at the top and bottom.
6698.6 In reply to 6698.5
Hi OStexo;
This worked perfectly.
Thanks!
-sharif
Show messages: All  1  2-6
