Extrude/Shell request
 1-4  5-24  25-30
6693.5 In reply to 6693.4
Hi Andrei,
> Michael, why not to make when you check - Cap Ends, apears new two check
> boxes - Cap 1 and Cap 2.
What would then happen if you checked "Cap Ends", but then unchecked "Cap 1" and "Cap 2", does that mean cap ends is on because "Cap ends" is checked or does it mean it's off because "Cap 1" and "Cap 2" are un-checked?
It's kind of weird to have UI structured in such a way that it can look simultaneously on and off with nested controls like that...
6693.6 In reply to 6693.5
Then make just one check box - Disable base surface :)!
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6693.7 In reply to 6693.5
>What would then happen if you checked "Cap Ends", but then unchecked "Cap 1" and "Cap 2", does that mean cap ends is on because "Cap ends" is checked or does it mean it's off because "Cap 1" and "Cap 2" >are un-checked?
Or... make it impposible to uncheck both caps. Only one can be unchecked to disable both you have to uncheck - Cap Ends.
Or if you uncheck both caps, Cap Ends unchecked automaticly and next time when you check it it will check both caps.
6693.8
I think - Disable base surface, is the best option :)
6693.9 In reply to 6693.7
Hi Andrei,
These sound like UI that would not really behave like any other checkboxes in the system, that kind of thing tends to easily lead to a confusing UI.
6693.10 In reply to 6693.8
I'd still prefer to focus on other better ways to achieve the end result rather than a special option that only eliminates one individual step.
It would be better if you could make a raised or indented area directly from an outline curve and avoid several of the other steps as well.
Or also another thing that might work is to automatically do the "disable base surface" thing when you are extruding a face that is part of a joined structure.
6693.11 In reply to 6693.10
Michael, What do you think if it will automaticly "disable base surface" if you extrude frome surface, joined surface and edges?
6693.12
Hi Andrei,
I don't get this, by the time I work out which check box to check or uncheck I can delete the unwanted face just as quick.
I just want to understand the reason for your request.
6693.13 In reply to 6693.12
DannyT,
becouse:
1. You can not see how deeper it goes
2. Check my example here a lot of pecise and you have to spend time to delete them all...
I just show this request in the start of topic on simple example but during work there are more complicated stuff even then I showed in this screen...
I meet this chalenge quite often, so thet is why I asked for this...
tr
Check this model it has A LOT OF stuff like this...Windows, doors, grils etc, etc... So to have this feature will make life MUCH more easer.....
wire
EDITED: 16 May 2014 by ANDREI SAMARDAC
6693.14 In reply to 6693.13
Hi Andrei,
I see what you mean, however for grooves like around the door I would use Construct > Offset > Inset.
Having a look at Inset and when 'Use separate height' is checked is it possible to have a zero thickness, at the moment it's not accepted, in that way I think that would suit Andrei's request.
6693.15 In reply to 6693.14
Agree with DannyT
It would be nice :)
shapenoid.com
6693.16 In reply to 6693.14
DannyT, good idea!
for me it does not matter what it will be Extrude, Shell or Inset, the main thing is - it should work in this case:)! So waiting for Michael reply.
6693.17
I think this is what I asked about here http://moi3d.com/forum/index.php?webtag=MOI&msg=5508.8
Martin.
6693.18 In reply to 6693.11
Hi Andrei,
Probably not for individual surface or edges since those can often be used for just regular simple extrudes where people are trying to generate a solid, but I think that it might work ok for the case of extruding a face that's a part of a joined surface.
6693.19 In reply to 6693.14
@Danny,
> Andrei's request.
I don't know... Inset is primarily focused on generating a border, with the border thickness as it's main input field at the top of the command.
So it seems kind of awkward to focus on disabling thickness inside of it. For example since the command is primarily focused on thickness when you pick 2 points with the mouse it sets the thickness, not the optional "separate height" height.
It seems like it might fit better as an option in Offset, maybe something like "build side walls"... The thing that makes me pause about that is that there is then some duplicate overlap functionality between offset and shell, since if you select an entire surface object Shell will thicken it with side walls constructed already. The main difference would be the behavior when there is a face selected instead of a whole object selected, shell uses that as the opening and thickens everything else.
6693.20 In reply to 6693.19
Michael, if it is so problem for you to incorporate this command into existing ones, could you pleas make just script without any UI icons, just script.
In wich you can shell/extrude without base surface.
6693.21 In reply to 6693.20
Hi Andrei, re: script version without UI - unfortunately I think it would be difficult for a script to work only by a slight modification of the existing command, because I don't think the script will have a reliable way to figure out which particular face in the generated object should be deleted.
So a script version would probably have to work fairly differently from the regular command and instead build the pieces like side walls and top piece itself and join them together. That's not a small change to the existing script, it's a pretty different thing and would be somewhat time consuming to develop, so I'm sorry I probably won't be able to make that right now.
But why wouldn't the other method that I was describing previously work for you? That would be where the base surface would be deleted when extruding a face that's part of a joined surface, the extrusion would basically become another part of the joined surface structure.
6693.22 In reply to 6693.21
Michael, I'm not sure I understand how this method works.
6693.23 In reply to 6693.22
Hi Andrei,
I mean that if you have an object like this where the surfaces are joined together, here with a face sub-object selected:
Then when you extrude that (again, those surfaces are joined, not independent and it's one face sub-object of the full object selected), I could remove the base surface and automatically make a joined result like this:
So the main way to trigger this would be to join the pieces before doing the extrusion.
6693.24 In reply to 6693.23
Michael, looks good, i'll wat for this feature.
Show messages:  1-4  5-24  25-30
