Extrude/Shell request
 1-5  6-25  26-30
6693.26 In reply to 6693.25
Hi Pilou, sorry I'm not really understanding what your A B and C are supposed to be there...
Keep in mind Booleans are focused on working with solid volumes, they try to cut a solid up and generate a solid as the result, not switch a solid into an open surface.
6693.27 In reply to 6693.26
More easy!
Improvement!
Like this! ;)
PS Same result if plane rectangle B is yet on the face of A !
So Extrude B, select All then Boolean Union!
EDITED: 18 May 2014 by PILOU
6693.28 In reply to 6693.27
Hi Pilou, yes that does work with boolean union, good idea! That may help for the time being.
6693.29 In reply to 6693.27
Good, idea but still can not see how deep goes extrusion or shell... Michael May be you can make hiden line visible wehn make extrusion or shell?
6693.30 In reply to 6693.29
Yes because that is "before function" : you must to know before how you extrude the volume! ;)
Show messages:  1-5  6-25  26-30
