BSpline ??
All  1  2
6691.2 In reply to 6691.1
Hi niko,
> Exactly how did Andrei create those corner points without checking that box??
If you hold down the Ctrl key when you click, that's a shortcut for placing a corner point without needing to check the box.
> Is this some new continuous curve?
It's just the regular Draw curve > Freeform > Control points, just using the Ctrl key shortcut.
> If it were to be lofted would MOI not create an extra edge/seam at those corner points?
If it were to be lofted, there would be edges there - any time a surface would have a sharp crease in it you will have an edge along that spot.
Show messages: All  1  2
