Large vector files - slow performance
All  1  2-6
6685.2 In reply to 6685.1
Hi dan, well yes just in general dealing with a very high number of objects will bog things down.
If you don't see very much difference with things hidden, that means that you've got so many individual objects that the time to just iterate through all objects is becoming significant even though the ones marked as hidden are not processed any further.
In the future I want to improve this by making a separate list of visible objects so ones that are hidden won't even be iterated through. I expect to work on that in the v4 time frame, it's a bit too delicate of an area to mess with this close to the end of the v3 release.
For now in this particular case of some tremendous number of individual little objects you'll probably need to separate things into totally different files if things are bogging down too much.
6685.3 In reply to 6685.2
Sounds like you've got it in hand in V4. In the mean time I might try and come up with some sort of pre-filter operation to remove lines that are smaller than some defined dimension. There are a lot smaller lines (hidden detail dashed lines and other spurious lines) that I could do without. Is this something that could easily be implemented with an MOI script? I might do some research.
BTW: I've really been enjoying using MOI lately, it's a breath of fresh air after using my normal 3D CAD programs - SolidWorks and Solid Edge. Thanks for a great product.
6685.4 In reply to 6685.3
Hi dan, I'm glad that you're liking MoI! :)
Check out this script - it will select objects smaller than a particular bounding box size (measured by the diagonal of the bounding box):
http://kyticka.webzdarma.cz/3d/moi/#SelectTiny
6685.5 In reply to 6685.4
Thanks so much for the script link, it's exactly what I was looking for - now I don't even have to wait for v4!
6685.6
I opened a similar thread for this issue a while ago, I'm also working with many objects in the scene and I am experiencing some lag also when I hide everything and draw. Fortunately making a copy\paste in a new file of just the objects I need to work on and then pasting back solves my issue for now, yet an optimization of the cycle of the objects would be even better, hopefully for v4 :)
thank you!
Show messages: All  1  2-6
