Shell problem
All  1  2-4
6675.2 In reply to 6675.1
Hi Andrei, MoI's shell function is not sophisticated enough to deal with situations where the thickening would cause one vertex on the base surface to branch out into 2 different vertices on the offset. It's unfortunately a big limitation in the geometry library's solid offsetting function.
Probably your best bet would be to import the object into a different CAD program like ViaCAD which has an engine that handles shelling better than MoI.
Otherwise, the manual way to do it is to create offsets on individual separated surfaces and build extensions between the offsets as needed. That will involve quite a bit of work so probably using a different CAD program with a more robust thickener would be better.
6675.3 In reply to 6675.2
Thank you
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6675.4 In reply to 6675.1
Also see here for some previous discussions:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5385.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6038.1
The manual steps for that type of construction is explained here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6038.9
Usually the offset of such a structure is a lot more complex than you might initially think, when the planes are all at different angles to one another then the offset structure does not have a single meeting point, this is illustrated in some of the above discussion.
Show messages: All  1  2-4
