Polygonal Converter.
 1-3  …  44-63  64-83  84-103  104-123  124-143  …  464-483
6674.84 In reply to 6674.82
Hi Max, cool stuff! Looks like it is working well for valence=4 vertices currently.
How is a reasonable number of polys of an import obj file?
Try with these 2 ones separated from ZBrush with no result ;)
_importObj works fine
_subdiv_beta open for gear but...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/pm3d_dog_1.obj quadrangles 8 000
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/pm3d_gear3d.obj triangles 3 300
EDITED: 6 Oct 2014 by PILOU
And have you project for that or not ?
And this one ?
No caps in the result ! Does this normal ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nocaps.3dm
6674.88 In reply to 6674.86
Frenchy,
""""""""""""""And this one ?
No caps in the result ! Does this normal ?""""""""""""""
You can trim the top and bottom faces of this type of object:
The other one looks like something is greater than 5? Maybe look to have at the most a quad case....
6674.89 In reply to 6674.88
Hey Frenchy,
Here's a trick for you. You can subdivide up your ngons to allow them to work....
6674.90 In reply to 6674.89
Max,
I love that the objects points remain editable!
If you can figure out how to keep the original faces and smoothing attached, this will be a mind blower... Replacing hexagon for me.... essentially, "box modeling" in MoI..... :o
6674.91 In reply to 6674.87
Hi Pilou
100-200
I think this script will be more useful for subdivision modelling (like Siemens NX).
>>And have you project for that or not ? (Error: N>5)
As I said above, this script supports 3- 4- and 5-sided polygons only.
>>No caps in the result ! Does this normal?
Yes, it's normal. Pentagons isn't supported in fast mode.
Cool
Thx for the infos and tips and tricks!
6674.93
This is great! Thanks Max!
6674.94
Fantastic! You da man, Max, many thanks!
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6674.95
Sweet baby jesus this is powerful stuff. Max, I can't begin to tell you how thankful I am that you've implemented this and shared with the community.
While I only started a year or so ago with MOI as a step from STEP to FBX conversion, MOI has become such an invaluable tool that I've more or less gone from Maya polygon modelling to MOI parametric modelling* after nearly 15 years of using Maya. This addition feels like the last missing link between the two. Subdivision sketching can now be brought into MOI for finalizing.
Thank you, thank you, and thank you again.
/Rico Holmes.
*Yes, MOI's THAT good.
6674.96 In reply to 6674.95
Same here, Rico. 14 years of 3ds Max (1998-2012), then I moved to Blender 3D (which is still my preferred 3D all-rounder), and not long after that MoI entered my life and stole my heart. ㋡
The only thing I really missed in MoI was the powerful branching of polygon subdivision modeling, but Max built an interesting bridge to that now.
Don't forget ExplodeMove after subdivide for cool possibilities!
6674.98 In reply to 6674.97
Pilou, it looks great :)
P.S. Small update (Unsupported polygons stays selected)
EDITED: 7 Mar 2022 by SMIRNOV
6674.99 In reply to 6674.98
Cool! ;)
6674.100
Cool stuff Max!
6674.101 In reply to 6674.91
Wow!
Thank You very much!!!
6674.102
Finally found the time to try this cool script.
It looks great. Thanks a lot, Max! I especially love the minimal number of control points.
A question:
When using the max number of subdivs, you still see seams along the surface edges. Will those be gone in the Quality mode? Would be great if the surfaces would have seamless continuity.
All the best,
Metin
6674.103 In reply to 6674.102
Hi Metin,
Thank you. This was one of the main tasks.
I'm working on it. Fast mode will be used for interactive tuning only.
Yes. At least I hope so :)
Show messages:  1-3  …  24-43  44-63  64-83  84-103  104-123  124-143  144-163  …  464-483
