Polygonal Converter.
 1-4  …  25-44  45-64  65-84  85-104  105-124  …  465-483
6674.65 In reply to 6674.64
Hi Brian, I using this one
Fast Parallel Construction of Smooth Surfaces from Meshes with Tri/Quad/Pent Facets
A. Myles and T. Ni and J. Peters
https://www.cise.ufl.edu/research/SurfLab/papers/08poly.pdf
It can use any solid object with flat faces, which can be created in MoI, or imported using my importobj script.
P.S. Also you can read this document: Smooth Surfaces from 4-sided Facets
T. L. Ni, Y. Yeo, A. Myles, V. Goel and J. Peters.
EDITED: 30 Sep 2014 by SMIRNOV
6674.66 In reply to 6674.65
Wow Max..... Wow.
Your importobj script? Did I miss that one or is it part of this project?
6674.67 In reply to 6674.63
I second that Wow!
6674.68 In reply to 6674.66
Ops.. I forget to share it here :)
Yes, I wrote it as a part of this project, but it can be used separately.
EDITED: 7 Mar 2022 by SMIRNOV
6674.69 In reply to 6674.68
Really cool stuff Max!
6674.70 In reply to 6674.69
Thank you Michael.
I still having an issues with extraordinary vertices because I didn't finished with Pm-Patches yet. I hope it will be really cool but a little bit later :)
I plan to release a stable beta at weekend.
Sorry where is the Subdiv command ?
It's the one you want release this weekend ?
6674.72 In reply to 6674.71
At this moment subdiv script is not ready for public release. Wait a few days. :)
6674.73 In reply to 6674.72
Ok Cool! Thx for the info!
Really amazing Max!
Best regards
6674.75 In reply to 6674.74
Hi Max,
Hope their will be a little 'donate' button somewhere so we can buy you a drink or something :)
Hi Max:
For the 2008 paper, ....Tri/Quad/Pent Facets, there is source code and a movie here:
http://www.cise.ufl.edu/research/SurfLab/pubs.shtml
There is an errata file with corrections for page 5 and 6 here:
http://www.cise.ufl.edu/research/SurfLab/papers_html/myles08fast_errata.txt
There is a 2009 paper as well.
6674.77 In reply to 6674.75
(Hope their will be a little 'donate' button somewhere so we can buy you a drink or something :) )
I'll second that! Very cool, Max.
Ron
6674.78
Agree with Paq !
Thanks Max!!
M
6674.79
Amazing !
6674.80
Wow. Really great stuff, Max! This looks like the ideal bridge between poly and NURBS modeling.
I'm wondering: how clean are the smooth surfaces that are generated, in terms of surface points amount when separated? It would be fantastic if the smoothed version of a model remains adjustable after the smoothing.
Also, models converted with T-Splines in Rhino have trouble managing vertex points with 5 edges (so-called star points), resulting in a visible surface continuity artifact where quad polygons meet at a star point. How does your script manage those?
Can't wait to have a go at this!
Thanks!
Metin
6674.81
TSplines-like modeling in moi? That sounds incredibly useful. Thank you for your effort.
Max.
6674.82
Here is the first public release of the subdiv script :)
In fact this is only a half of the script. It works correctly with ordinary and polar vertices only. But it still has some problems with extraordinary vertices in some cases. I'll finish the second half of the script in nearest future. There will be two methods of subdivision: fast and accurate. Here is an implementation of the fast mode only.
Usage:
Select one solid or group of solids. Run script.
P.S. Would like to thank everybody for support. Thank you!
The idea about a donate button is good. Maybe sometime, but not now :)
6674.83 In reply to 6674.82
Thanks :o
6674.84 In reply to 6674.82
Hi Max, cool stuff! Looks like it is working well for valence=4 vertices currently.
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-124  125-144  …  465-483
