Polygonal Converter.
 1-13  14-33  34-53  54-73  74-93  94-113  …  474-483
6674.54 In reply to 6674.53
Very impressive !
eric
Cool!
So what will be the export ? If you export in OBJ : object will be segmented again by the MOi mailer ?
6674.56 In reply to 6674.53
Max, do you have a link to the algorithm?
I came across this: http://www.cl.cam.ac.uk/techreports/UCAM-CL-TR-773.pdf
Thank you,
6674.57 In reply to 6674.56
6674.58 In reply to 6674.57
Hi Max, the difficulty comes with the "extraordinary vertices" - vertices where other than 4 edges are coming off of it.
The subdivision surface behaves somewhat differently in those areas and those are the problematic parts to put NURBS surfaces on.
6674.59 In reply to 6674.58
Hi Michael.
I am not confident of success, but I'll try to implement Jos Stam's method of calculating the surface exactly.
[added] open mesh support
EDITED: 7 Mar 2022 by SMIRNOV
6674.60 In reply to 6674.59
Hi Max,
Ok, but evaluating the subdivision surface exactly does not really solve the problem of conversion of the surface into a different form...
I think what you will end up finding is that regular areas of the mesh will convert quite nicely but that there will be difficulties in the areas of extraordinary vertices.
But I'm looking forward to seeing what you come up with anyway! :)
6674.61 In reply to 6674.60
Michael,
Could the "extraordinary vertices" be easily identified beforehand? This tool, even if there were parts that had to be "left out", would be very cool. Then using other tools to handle the extraordinary part...
6674.62 In reply to 6674.61
Hi Burr, yeah the extraordinary vertices are pretty easy to identify, they're just vertices where there is some other number than 4 edges coming off of the vertex, see here:
http://www.multires.caltech.edu/teaching/courses/subdivision/intro/sld012.htm
6674.63
This is early beta version of my subdiv script. I'll add more features later. High precision mode (for extra smoothing around an extraordinary vertices), per edge sharpness, and more. Script supports 3- 4- and 5-sided polygons.
6674.64 In reply to 6674.63
Hi Max, Which scheme are you using?
http://www.holmes3d.net/graphics/subdivision/
Is it going from Nurbs to Nurbs or ?
6674.65 In reply to 6674.64
Hi Brian, I using this one
Fast Parallel Construction of Smooth Surfaces from Meshes with Tri/Quad/Pent Facets
A. Myles and T. Ni and J. Peters
https://www.cise.ufl.edu/research/SurfLab/papers/08poly.pdf
It can use any solid object with flat faces, which can be created in MoI, or imported using my importobj script.
P.S. Also you can read this document: Smooth Surfaces from 4-sided Facets
T. L. Ni, Y. Yeo, A. Myles, V. Goel and J. Peters.
EDITED: 30 Sep 2014 by SMIRNOV
6674.66 In reply to 6674.65
Wow Max..... Wow.
Your importobj script? Did I miss that one or is it part of this project?
6674.67 In reply to 6674.63
I second that Wow!
6674.68 In reply to 6674.66
Ops.. I forget to share it here :)
Yes, I wrote it as a part of this project, but it can be used separately.
6674.69 In reply to 6674.68
Really cool stuff Max!
6674.70 In reply to 6674.69
Thank you Michael.
I still having an issues with extraordinary vertices because I didn't finished with Pm-Patches yet. I hope it will be really cool but a little bit later :)
I plan to release a stable beta at weekend.
Sorry where is the Subdiv command ?
It's the one you want release this weekend ?
6674.72 In reply to 6674.71
At this moment subdiv script is not ready for public release. Wait a few days. :)
6674.73 In reply to 6674.72
Ok Cool! Thx for the info!
Show messages:  1-13  14-33  34-53  54-73  74-93  94-113  114-133  …  474-483
