Polygonal Converter.
 1-15  …  96-115  116-135  136-155  156-175  176-195  …  476-483
6674.136 In reply to 6674.135
Hi Mauro,
> I tried -ImportObj- with Lisa-head from C4D
That looks very dense - is it a several times subdivided result that is being exported? If so then you want to try exporting the base level control mesh rather than already subdivided geometry.
6674.137 In reply to 6674.136
Ciao Michael
Lisa comes from C4D content browser,she's already subdivided
6674.138 In reply to 6674.135
I joined small patches (much quicker) to few bigger patches and after all I joined all bigger patches into one solid. Much quicker than do it as one time consuming process (I used that for that bottle above). Maybe that helps.
EDITED: 3 Feb 2015 by MDESIGN
6674.139 In reply to 6674.137
Hi Mauro,
just in case you need to recover her... ;-)
http://www.mariussilaghi.com/products/subd-recovery
6674.140
Finema
>any idea about my problem above ?
Sorry, I don't have a mac. But it's very strange, it should work.
6674.141 In reply to 6674.140
Max,
I've tested all the example in this thread (and more) and none are running.
I've a 2 x 2,8 GHz Quad-Core Intel Xeon Mac Pro and 6 Go ram.
The Subdivision panel displays a split second and disappears.
No other Mac user had this problem ? It's curious...
Thanks...
6674.142 In reply to 6674.141
Hi, yes I am a mac user as well and when running the script I see a window flashing up on the left upper corner and that is it.
Maybe this will be resolved soon but anyway your work is awesome !!
6674.143 In reply to 6674.142
For me the subd script works well with MoI 2.52 (have not updated yet to 3.0) under OSX 10.8.5 with my old iMac.
6674.144 In reply to 6674.141
Finema
Kroet
Check beta1 or beta2. Does it work?
6674.145
Beta 5.
Fixed bug with high valence vertices (>16-20)
Some surface tuning. Not perfect, but smoother than beta4.
b4 - red, b5 - green
Upd: Fixed tolerance bug, which may cause errors while importing very small models. Reuploaded.
EDITED: 7 Mar 2022 by SMIRNOV
Voluptuous!
6674.147 In reply to 6674.146
As in the beta4, The Subdivision panel displays a split second and disappears.
6674.148 In reply to 6674.147
have you tried to use beta 1 or 2?
6674.149 In reply to 6674.148
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
6674.150 In reply to 6674.149
6674.151 In reply to 6674.150
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
EDITED: 28 Jul 2018 by FINEMA
6674.152 In reply to 6674.151
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
6674.153 In reply to 6674.152
always the same problem
panel subdivision split and disapear
6674.154 In reply to 6674.153
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
6674.155 In reply to 6674.154
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
Show messages:  1-15  …  76-95  96-115  116-135  136-155  156-175  176-195  196-215  …  476-483
