unable to boolean subtract
All  1-4  5-7
I copied the cylinder edge to make it a curve, selected the few points after it curves down, to the end, moved the furthest one from the end up
a little bit, with the rest of the selected ones following along, and then did the circle sweep over again, using the modified curve. A bit crude.
EDITED: 4 May 2014 by BEMFARMER
6671.6
thanks all, it works indeed when moving the tubes a little, they were intersecting indeed.
another 2 things learned about MoI today! (didn't know about the intersection and about how to move points of a nurbs volume).
I thought I knew almost everything by now, but still...
next month I will be officially teaching with MoI!
cheers
wim
6671.7 In reply to 6671.6
So another thing to note here, is sometimes you don't want to, or cant start moving things around.
So with your example, you could cut the tube into 2 pieces (just before it starts to intersect) then union the 2 pieces together which will remove the intersecting surfaces and allow the Boolean to succeed.
Although, in this case, the intersection was so small and slivery, I had to do an interse3ction curves on the 2 pieces, then use "trim" to remove the little intersection surfaces and then join back to a solid and Boolean diff away from the block...
FYI.
Show messages: All  1-4  5-7
