Nurbs render?
All  1-12  13-19
667.13 In reply to 667.10
> Moi is Rock ! I love Moi !
I'm glad you like it! That's a beautiful smooth render.
667.14 In reply to 667.12
Hi Edwin,
> Modo 301 does support vertex smoothing and it looks great.
That's great! That will be a huge improvement for rendering CAD models.
The only problem is that currently there is nothing in the LWO spec for storing vertex normals inside of a LWO file, you will only currently get them in an OBJ export.
With their new version's support, they must have some kind of extension for the LWO format for storing normals in the LWO file. If I can find out the details of that format extension, then I could write the vertex normal data to LWO as well.
667.15 In reply to 667.14
Hello Michael,
this might be an interesting bit of information: The Lightwave exporter of Okino's PolyTrans offers the option to export vertex-normals in a "modo compliant way" as they call it. Here is how they describe it on the Okino website:
"Vertex Normals (Luxology MODO Compliant)
If this checkbox is enabled then vertex normals will be output to the .lwo object file. Vertex normals are needed to make an object appear smooth.
NOTE: at this time the Lightwave software does not have support for vertex normals in the .lwo file format; however, Luxology (developers of the MODO modeling program, and original developers of the Lightwave software) have implemented their own propietry "Vertex normals" chunk in the .lwo file. Okino has implemented this MODO compliant vertex normals chunk. The VMAP and VMAD type is "NORM" and the reference name is "vert_normals". Other software developers are free to add support for this added vertex normals IFF chunk in their Lightwave importers.
This option will be disabled when the Lightwave v5.6 file format version is selected."
(http://www.okino.com/conv/exp_lw.htm)
667.16 In reply to 667.15
Cool, hopefully Michael will be able to use this info for MOI - sounds like another checkbox is gonna be needed somewhere (or perhaps just an additional "LWO2" format specifier in the dropdown list...)
-Will
667.17 In reply to 667.15
Hi cronbg - thanks for passing this along, this is a useful bit of information on how to get stuff into the next version of Modo better.
I've added this data to MoI's LWO export for the next beta release, which I'm hoping to put out tomorrow.
I don't really have any way to test it to make sure it works though, because only Modo version 301 is supposed to support this and I don't have that over here. But in that version, this data should make a pretty nice difference for improving the smoothness of shading.
@Will - Actually I don't think that a checkbox will be needed for this, MoI is already saving out LWO2 style files (which still end with .lwo, they are an updated version of LWO that doesn't have the 65536 points-per-object limitation that the original LWO had). One thing that is nice about LWO files is that they are structured in such a way that programs can easily skip chunks of data that they don't recognize. So other programs that don't know how to process vertex normals should just skip right over them.
667.18 In reply to 667.17
wow, thank you so much, this is really cool!
I can't wait to get my hands on modo 301 to see how it works. This will work wonders for industrial designers like me who have to deal with a lot of NURBS and parametric solids but need high quality meshes for virtual product shots.
I think with MoI's excellent NURBS to polygon conversion capabilities, you have a real gem on your hands.
EDITED: 15 Jul 2007 by CRONBG
667.19 In reply to 667.18
Okay great Michael, not knowing details on the LWO format, I didn't realize it was based around chunks similar to tiffs...
Glad to hear it wasn't hard for you to get this into the next beta!
Even though I've sorta settled with using Cinema 4D now (thanks to all of you folks here ;-) ), I will certainly appreciate the effort when Newtek finally gets their act a bit further into this century!
-Will
Show messages: All  1-12  13-19
