3D connexion
All  1-4  5-10
It seems to be the 3DX driver does not handle the buttons with any XQuartz application which is what MoI on OSX currently uses to run.
Seems to be a similar problem reported on their forum here:
http://www.3dconnexion.com/forum/viewtopic.php?f=23&t=7314
I don't know what I can do myself to fix this currently, it's probably something that would need to be tuned up either in the driver or in XQuartz. In the future at some point I'd like to try and get MoI to not use XQuartz and that would probably make this work at that point but for now I don't think it will be possible to use the device buttons with MoI, sorry.
6661.6 In reply to 6661.5
I got around it by using an app called ControllerMate, which I use for other things anyway.
6661.7 In reply to 6661.6
Hi mushcraft, that's great that there is a way to make it work with ControllerMate.
Is it difficult to set up ControllerMate to work with the 3DConnexion device or is it pretty straightforward?
6661.8 In reply to 6661.7
It's very simple, just a matter of connecting a few visual programming blocks together. Essentially every connected input device's axes and buttons shows up. It's trivial to add chording and multiple-press actions as well.
6661.9 In reply to 6661.8
@mushycraft
I just installed ControllerMate... it detects my 3dconnexion and i put some controllerBlocks to a new page. ControllerBlock for the axis gave a feedback in ControllerMate but the ControllerBlock for the buttons don't respond to a click...??
am i doing something wrong?
6661.10 In reply to 6661.9
Make sure you're using the blocks for the individual buttons, and not the one for the button group (though if you go into the options for that one you can make it work too).
Show messages: All  1-4  5-10
