Rail Extrude w/Corner?...
All  1  2-4
666.2 In reply to 666.1
Work with two rails, for second rail helps ShellCommand
BestReg`s EDDI
666.3 In reply to 666.2
Okay, thanks Eddi - I'll try that!
I guess I was thrown off coming from Rhino and seeing how this works there...
I guess there's must be some additional programming required for it to handle the turn using a single rail like that?
Thanks!
-Will
666.4 In reply to 666.3
Hi Will, yup it actually takes a fair amount of additional programming to handle the sharp turns. It involves extending the portions along each segment and then doing a mitered intersection to make the corner. Rhino has special code in it to handle this.
I started to work on it at one point, but it was taking quite a bit of time so I postponed it for a while, I don't think I will be able to squeeze it in for V1 but it will definitely be coming at some point after that.
For the 2 rail workaround method, you may sometimes want to put the rails on either side of the shape too - here is another thread with some info: http://moi3d.com/forum/index.php?webtag=MOI&msg=428.12
Show messages: All  1  2-4
