Distort Curve script
 1-16  17-36  37-56  57-62
6659.57 In reply to 6659.55
Hi mikebres,
I see that you have "My.scripts" and also "All.scripts" in the custom ui. Maybe that is the problem?
I've never set up that way. I think Burr had some such posts a while back, in the custom ui discussion?
Maybe here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.58
Normally using the scripts is "easy."
The original Moi Shortcut key method should work well, and "easy." Both methods can be set up, and work "side by side."
EDITED: 17 Dec 2014 by BEMFARMER
6659.58 In reply to 6659.57
Does your ini file have an old path in it?
6659.59
That was it. It needed to be setup as a shortcut. For future reference how are we to know which way to set it up?
6659.60 In reply to 6659.59
The customui just automatically finds and uses "what you have"... ot comes kindof preconfigured with some stuff " hence the underscore command that doesnt exist... i suspect your config files arent setup quite correct.
6659.61 In reply to 6659.60
The config for MOI, or the Custom UI? Thanks.
6659.62 In reply to 6659.61
Both.
Check your MoI ini file to see if it has an executable path in it and if it pointing at the installation you are using...
Also, I think I remember the customUI comes with some of the commands "preconfigured" with some of the scripts/commands, and included that underscore.... It's been awhile, so I don't remember off the top of my head, and I am not at my install setup to check the original stuff...
Either someone else can chime in on it, or I'll get a look a bit later and get back to you....
Show messages:  1-16  17-36  37-56  57-62
