Distort Curve script
 1-10  11-30  31-50  51-62
6659.31 In reply to 6659.30
Michael, Thank you I'll try :)
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6659.32
And sweet candy!!!
candy
6659.33 In reply to 6659.32
> And sweet candy!!!
Ha, good one! Finally a case where some wrinkling in loft was useful... :)
Loose loft looked too smooth for this case.
6659.34 In reply to 6659.33
Michael, yep, wrinkling works great)) Yes loose is not very good for gathers.
2014 05 03 11 30 39 [ Front]
Sweet candy!
6659.36 In reply to 6659.27
Thanks Michael
6659.37 In reply to 6659.27
>> @Max - changes were: added a "Rebuild" checkbox and an input for number of points to use.
Thank you very much! the script is great now.
P.S. I'm very busy at work during last months. So, I haven't enough time for programming.
6659.38 In reply to 6659.37
Max,
I really appreciate the scripts you make and that you share them with us. Thanks.
6659.39 In reply to 6659.9
As a side note, thanks for posting that video. I didn't realize you could type commands into the text box at the bottom. That is something I really like about Rhino (big time saver), and now I know I can do it in MoI too! Can't wait for v3 so I can see if it will work on my Linux machine. :)
6659.40
Michael could you pleas make this script to keep style after applying it?
6659.41 In reply to 6659.40
Hi Andrei,
Please try updating with the attached file, this should preserve properties like style and object name on the distorted curve.
6659.42 In reply to 6659.41
Thank you!!
My Portfolio: www.samardac.com
6659.43 In reply to 6659.42
Hi Andrei
Don't know if this has been asked before (have not been around lately :) ) how do you setup the commands menu popup in MoI? thats in your video?
Cheers, Stephen
6659.44 In reply to 6659.43
Hi Stephen,
That pop up menu is part of Max Smirnov's custom GUI he developed, you can find it at the following link
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
6659.45
Is v0.8 the latest version? Because it doesn't seem to include that rebuild command that can be seen in Max' videos.
Or is there a central place with all of his scripts?
6659.46 In reply to 6659.45
Post 27, version 0.9
6659.47 In reply to 6659.46
Mhh, must have overlook that. Thanks!
6659.48
Any idea what I might be doing wrong? Unzipped version .09, copied the files to a script folder identified using Custom UI. Also, tried putting the files in the command folder. I'm using version 3 of MOI.
6659.49 In reply to 6659.48
The function init() is in the .htm file.
So is the .htm file missing from the /Commands folder?
(extension cannot be .html)
This error occurs when the DistortCurves.htm file is missing, (or misspelled), from the Moi3.0 /Commands folder.
EDITED: 14 Dec 2014 by BEMFARMER
6659.50
I checked. It's spelled correctly, plus I added the updated htm file from the forum. Any other ideas? :)
Show messages:  1-10  11-30  31-50  51-62
