Distort Curve script
 1-5  6-25  26-45  46-62
6659.26 In reply to 6659.18
"""""BurrMan, all you need with that script is enter - RMD and it will produce randomely distorted curve, or RMD*10, RMD*20 etc..."""
Perfect. Thanks Andrei.
6659.27 In reply to 6659.18
Hi Andrei,
> It will be great to have rebuild integrated into Distort Cuves script to see imediatly
> result ant to be able to corect it on the fly.
> Max have no time to modify this script so may be you will help to finish it?
An updated version with rebuild built in is attached.
@Max - changes were: added a "Rebuild" checkbox and an input for number of points to use.
Added a RebuildCurve function and split init() into 2 functions init() and initpoints() so that when a rebuild option changes initpoints() can be called to extract points again.
Thanks for making this script Max!
EDIT: updated script to copy properties on to distorted version so style and object names will persist.
EDITED: 24 Jul 2014 by MICHAEL GIBSON
6659.28 In reply to 6659.27
Thanx Michael, works great, but one thing is have to be fixed for example if curve have 50 units long it works good but if curve for example have 2000 units long it does not work, nothing distorting... I have to enter value by hands.
EDITED: 3 May 2014 by ANDREI SAMARDAC
6659.29
And little tutorial, how I use this script to make curtain, in project I am workin on.
6659.30 In reply to 6659.28
Hi Andrei,
That doesn't have anything to do with the rebuild part, it's just how the script is currently set up, it uses a sort of base displacement of 0.2 units.
If you'd like something that's relative to the overall size of the curve rather than a more fixed size displacement, try changing the randomizePoints() function inside _DistortCurves.htm to this:
			function randomizePoints()
				for ( var i=0; i<curves.length; i++ )
					var size = scurves.item(i).getBoundingBox().diagonalLength / 20.0;
					for ( var p=0; p<curves[i].length; p++)
						curves[i][p].dx = size*(Math.random()-0.5)/5;
						curves[i][p].dy = size*(Math.random()-0.5)/5;
						curves[i][p].dz = size*(Math.random()-0.5)/5;
				lastdistort=-1;
This version puts in a scale factor that's related to the bounding box size of the object so the displacement on your 2000 unit long curve should work a bit more naturally this way.
6659.31 In reply to 6659.30
Michael, Thank you I'll try :)
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6659.32
And sweet candy!!!
candy
6659.33 In reply to 6659.32
> And sweet candy!!!
Ha, good one! Finally a case where some wrinkling in loft was useful... :)
Loose loft looked too smooth for this case.
6659.34 In reply to 6659.33
Michael, yep, wrinkling works great)) Yes loose is not very good for gathers.
2014 05 03 11 30 39 [ Front]
Sweet candy!
6659.36 In reply to 6659.27
Thanks Michael
6659.37 In reply to 6659.27
Thank you very much! the script is great now.
P.S. I'm very busy at work during last months. So, I haven't enough time for programming.
6659.38 In reply to 6659.37
Max,
I really appreciate the scripts you make and that you share them with us. Thanks.
6659.39 In reply to 6659.9
As a side note, thanks for posting that video. I didn't realize you could type commands into the text box at the bottom. That is something I really like about Rhino (big time saver), and now I know I can do it in MoI too! Can't wait for v3 so I can see if it will work on my Linux machine. :)
6659.40
Michael could you pleas make this script to keep style after applying it?
6659.41 In reply to 6659.40
Hi Andrei,
Please try updating with the attached file, this should preserve properties like style and object name on the distorted curve.
6659.42 In reply to 6659.41
Thank you!!
My Portfolio: www.samardac.com
6659.43 In reply to 6659.42
Hi Andrei
Don't know if this has been asked before (have not been around lately :) ) how do you setup the commands menu popup in MoI? thats in your video?
Cheers, Stephen
6659.44 In reply to 6659.43
Hi Stephen,
That pop up menu is part of Max Smirnov's custom GUI he developed, you can find it at the following link
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
6659.45
Is v0.8 the latest version? Because it doesn't seem to include that rebuild command that can be seen in Max' videos.
Or is there a central place with all of his scripts?
Show messages:  1-5  6-25  26-45  46-62
