Distort Curve script
 1-18  19-38  39-58  59-62
6659.19 In reply to 6659.18
Hi Andrei, do you need all the different options and modes of Rebuild to be all built in or are you looking for one specific mode like "# of points" mode?
6659.20 In reply to 6659.19
Michael, one specific mode like "# of points" will be enough.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6659.21
v.0.9
[Added] Closed curves support
[Changed] Distort slider values. Now Distort(10) = +- 1 unit. If you use mm unit system, Distort(10) = +- 1mm. Distort (150) = +-15mm, etc.
[Fixed] Pilou's bug. (I can't reproduce it, but I added one more check. Now this bug should be fixed. Pilou, try this version.)
EDITED: 7 Mar 2022 by SMIRNOV
6659.22 In reply to 6659.17
Hi BurrMan
>>Now looking at your youtube, I see the "flythrough camera". Are you working on that or did I miss a post you made?
It was a tech demo :) I have an idea to write flycam script, but I haven't free time for it.
6659.23 In reply to 6659.21
Thanks Max!
6659.24 In reply to 6659.21
@Max
Works fine this time! :)
Except maybe some lines and curves of the Sphere ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/glitch.3dm
EDITED: 2 May 2014 by PILOU
6659.25 In reply to 6659.24
Frenchy,
"""""""""Except maybe some lines and curves of the Sphere ?"""""""""
The curves/lines need more points. Are those "2 point entities?"
6659.26 In reply to 6659.18
"""""BurrMan, all you need with that script is enter - RMD and it will produce randomely distorted curve, or RMD*10, RMD*20 etc..."""
Perfect. Thanks Andrei.
6659.27 In reply to 6659.18
Hi Andrei,
> It will be great to have rebuild integrated into Distort Cuves script to see imediatly
> result ant to be able to corect it on the fly.
> Max have no time to modify this script so may be you will help to finish it?
An updated version with rebuild built in is attached.
@Max - changes were: added a "Rebuild" checkbox and an input for number of points to use.
Added a RebuildCurve function and split init() into 2 functions init() and initpoints() so that when a rebuild option changes initpoints() can be called to extract points again.
Thanks for making this script Max!
EDIT: updated script to copy properties on to distorted version so style and object names will persist.
EDITED: 24 Jul 2014 by MICHAEL GIBSON
6659.28 In reply to 6659.27
Thanx Michael, works great, but one thing is have to be fixed for example if curve have 50 units long it works good but if curve for example have 2000 units long it does not work, nothing distorting... I have to enter value by hands.
EDITED: 3 May 2014 by ANDREI SAMARDAC
6659.29
And little tutorial, how I use this script to make curtain, in project I am workin on.
6659.30 In reply to 6659.28
Hi Andrei,
That doesn't have anything to do with the rebuild part, it's just how the script is currently set up, it uses a sort of base displacement of 0.2 units.
If you'd like something that's relative to the overall size of the curve rather than a more fixed size displacement, try changing the randomizePoints() function inside _DistortCurves.htm to this:
			function randomizePoints()
				for ( var i=0; i<curves.length; i++ )
					var size = scurves.item(i).getBoundingBox().diagonalLength / 20.0;
					for ( var p=0; p<curves[i].length; p++)
						curves[i][p].dx = size*(Math.random()-0.5)/5;
						curves[i][p].dy = size*(Math.random()-0.5)/5;
						curves[i][p].dz = size*(Math.random()-0.5)/5;
				lastdistort=-1;
This version puts in a scale factor that's related to the bounding box size of the object so the displacement on your 2000 unit long curve should work a bit more naturally this way.
6659.31 In reply to 6659.30
Michael, Thank you I'll try :)
6659.32
And sweet candy!!!
candy
6659.33 In reply to 6659.32
> And sweet candy!!!
Ha, good one! Finally a case where some wrinkling in loft was useful... :)
Loose loft looked too smooth for this case.
6659.34 In reply to 6659.33
Michael, yep, wrinkling works great)) Yes loose is not very good for gathers.
2014 05 03 11 30 39 [ Front]
Sweet candy!
6659.36 In reply to 6659.27
Thanks Michael
6659.37 In reply to 6659.27
Thank you very much! the script is great now.
P.S. I'm very busy at work during last months. So, I haven't enough time for programming.
6659.38 In reply to 6659.37
Max,
I really appreciate the scripts you make and that you share them with us. Thanks.
Show messages:  1-18  19-38  39-58  59-62
