Hi Robert,
> When importing files from Rhino5, MoI seems to skip all blocks and instances.
Yes currently MoI only looks for "regular" objects and does not deal with block instances in a 3DM file.
> The only work around seems to save that first as step in Rhino. That works fine in MoI.
Another way is to use the Explode command in Rhino and then save as a different 3DM file, the Explode command in Rhino converts block instances into regular independent objects.
> Also, not sure if planed, Instances would useful in MoI.
Yup, it's definitely something I want to add in the future, I'll probably be digging into it in the v4 time frame.
