Tablet problem.
6650.1
Michael, I tried today to work with tablet, but have some troubles, there is some lag when I try to rotate and zoom also when I start to Freeform-Sketch. You can see some blue circle when it start to lag.
I have Wacom, Intous 4 and it works good with other soft. What it can be?
subd
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6650.2 In reply to 6650.1
Hi Andrei, it sounds like it's probably some feature of the tablet software getting in the way like it's waiting to recognize a gesture or something like that.
See here for some tablet settings that you can adjust which may make a difference:
http://www.polycount.com/forum/showthread.php?t=73758
http://volnapc.com/how-to-get-rid-of-those-annoying-circles-from-your-wacom-cursor-in-windows-7
http://www.designimage.co.uk/how-to-remove-the-annoying-windows-7-circle/
6650.3 In reply to 6650.2
Thanks, solved!
Michael how can I set "Repeat" function alwas ON, in Freeform-Sketch?
6650.4 In reply to 6650.3
Hi Andrei,
You have to turn repeat on when you enter the command, then it will stay on until you finish that round of sketches.
But it's possible to modify the SketchCurve command itself to have a sort of internal automatic repeat to it, so that it would stay in the command doing sketch curves without using the regular repeat checkbox mechanism.
To do that, overwrite the regular SketchCurve.js in the commands folder with the attached version.
6650.5 In reply to 6650.4
Michael, thanx works very good especially with set CPLane command, becouse it always ON after I set CPlane Sketch is ON, no need to start it again.
