A question/request about the great moi3d
All  1-7  8-16
665.8 In reply to 665.7
> alas coding is another story :)
:) Yes, that is the hard part. But I can help if you need something not too complex.
665.9 In reply to 665.8
Thx but seems there is yet some crazy functions inside so maybe in another life :)
665.10 In reply to 665.5
>> I probably should have released a 1.0 version several months ago and then having the stuff I've been working on recently be the 1.x tune-ups...
I don't think so...
665.11 In reply to 665.6
Temporary WireFrame display mode -- to turn on or off face display.
Alt+W=script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
665.12
Lovely lovely lovey
moi3d quality improved 10X
665.13 In reply to 665.11
Thank you for this script Michael and Tyglik and for all your great scripts!
You truly have done wonders with MOI Scripting and given us some great new abilities with them!
I noticed at the end of this particular script there is no final semicolon, but there is in most if not all of the other scripts I have seen for MOI. Since most scripts have it I added it to your script here before installing it in MOI's Options Dialog and it works great! I wonder now though, Is the final semicolon required or just optional?
Thanks again,
- 3dvisuals dude
EDITED: 21 Jun 2007 by ODWYERVISUALS
665.14 In reply to 665.13
In that case it doesn't need a final semi-colon because the last part of the script is a "for" loop. A for loop normally looks like this when you have it spaced out more naturally:
for ( var i = 0; i < 10; ++i )
do_something();
do_something_else();
It doesn't normally need an extra semi-colon after the final closing } brace of the for loop. But it won't do any harm if you put one in, it is just the equivalent of an empty statement after the for loop.
Some other constructs do expect semi-colons, like at the end of function calls or variable assignments (like you can see _inside_ the for loop above). Actually some of those are also optional in the JavaScript language in certain circumstances, but it is best to put those ones in.
665.15 In reply to 665.14
Thanks Michael,
just thought I'd ask to be on the safe side!
I appreciate the thorough response too... I'm playing a tad with javascript in trueSpace now and some day when I grasp it all I'm sure the routines will be interchangeable to a large extent with slight modifications of course.
I really love the way you added easy script insertion capabilities into this last Beta by the way, thanks for that too!
- 3dvisuals dude
665.16 In reply to 665.15
You're welcome! I was getting tired of explaining about how to edit the moi.ini file manually... :)
Show messages: All  1-7  8-16
