Enumerate object names
All  1-5  6
6648.6 In reply to 6648.5
Hi andrew,
> edit: how does the current system work when I click on the top left name field and type
> in a new name? I can undo that operation, is this also a completely clone of all geometry
> that is being renamed?
I had to look it up, I had forgotten about this.
When you use the regular UI to edit the name it does set up a special undo unit that just contains object state (including name, style assignment, hidden and locked states), and just the geometry's ID number as a reference to it, rather than storing a clone of the actual geometry.
But currently the creation of these particular undo units is baked in to some specific functions like the property panel's name edit function (which includes showing the dialog as part of it), there isn't any way to trigger it by itself from script right now.
Show messages: All  1-5  6
