Search Replace Object Name
6646.1
I have a imported STEP file where each of the object names have a long string of text inn front of the actual object name. For example: CAMERA_PROJECT_FINAL_MSP349957
I'd like to be able to remove the "CAMERA_PROJECT_FINAL_" text from each object name but there's way too many objects to do my hand. Is there a script somewhere that search replace text in all the object names?
Scott
6646.2 In reply to 6646.1
Hi Scott, try this one:
script: /* Search and replace text in object names */ var search_text = 'CAMERA_PROJECT_FINAL_'; var replace_text = ''; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.name != '' ) { obj.name = obj.name.replace( search_text, replace_text ); } }
Set up a shortcut key and paste the above in for the command part, then when you trigger it, it will go through all objects (not just the selection) and replace the specified text inside of object names.
6646.3 In reply to 6646.2
Perfect! Works like a charm. Thanks Michael.
