Footwear
All  1  2-5
664.2 In reply to 664.1
Hi Juan!
> 1. - when there will be a new beta or commercial version?
There should be a new beta release very soon, within the next couple of days. I think there will be just one more beta after it before the full release.
> 2. - did you place some manual of MOI?
Not yet, I will be working on this after the software itself is complete.
> 3. - I send some works made in MOI for alone footwear it is question
> of applying some parameters of other programs
These look great, thanks for showing those! I'm not sure if I understand properly though - do you also have a question about moving these into other programs?
> 4. - to include conical extrude
Right now I was planning on including this for version 2.0. But here is a method that you can use to get the same result for the current version. Say you want to do a conical type extrude of this shape:
Draw a vertical line:
Select your base shape, and then run Construct / Sweep. Select the vertical line as the single rail. this will generate a cube shape, but go to the sweep options in the upper-right corner of the screen, and change the option for "Ends" to "Pointy end". That will make the sweep collapse to a point as it moves towards the end of the rail path, which should give you the same result as a conical extrusion:
Hope that helps!
664.3 In reply to 664.2
Hi Michael
Thanks for their attention:
Very good tip for conical extrude, and I explain it excuses for my English it is very short
My opinion is that MOI gives same results that other software that cost more money
Will plug-ins be included for rendered, machinist (CAM), 3d print, print?
Best regards
Juan Galvan
664.4 In reply to 664.3
Hi Juan,
None of these will be included for version 1.0, but I would like to enable more in all of these areas in future versions.
For version 1.0 it is necessary to export your data to a different program to do any of these functions. But MoI does support several export formats that should work with other programs, for example use STL, IGES or 3dm to bring data over to a CAM program, or OBJ format to bring data into a rendering program.
664.5 In reply to 664.2
Like I posted in the new feature section ... a taper and a bend function that uses curves as rails would be better
that function could be used on curves as well ....
Show messages: All  1  2-5
