polyline
All  1-12  13-16
6632.13 In reply to 6632.11
Hi Danny, one thing I sort of worry about with stuff like that is getting the whole screen sort of locked up with assistive or predictive things that you can no longer just freely place points anywhere you want, although it's more of a worry for freeform curve drawing than line and arc drawing.
But still what you show there seems to be cycling through quite a few different possibilities flashing on screen and that can bring a certain kind of learning curve needed to figure out how to control it... I can certainly see how it can be useful but there can be a fair amount of complexity that goes along with it too.
6632.14 In reply to 6632.13
I understand completely, I put this example up to clarify if this is what Eric meant.
I like the idea of setting up shortcut keys for Line and ArcContinue like you mentioned above, it would be nice when drawing a polyline to trigger the ArcContinue, in NX to get an arc you click/hold/drag, however I only see it for arbitrary drawing it would be difficult to get any accurate radii, as you said Michael 'seems to be cycling through quite a few different possibilities flashing on screen' and if you're not used to it, it can be quite daunting for the new user.
6632.15 In reply to 6632.14
Hi Michael and all ...
Now I do feel a little ignorant. I do so much architectural work ... mostly straight lines of one kind or another so I have not really explored arc's much at all ... mostly using fillet when I need to.
Now I see, thanks to your questions and suggestions, that indeed I can do what I am asking for already. I just happen to be doing some fairly large land development work in preliminary stages at the moment and wanted to be freer with walk and road layouts but not as loose as freeform lines. I took your suggestion and now can toggle between lines and continuingarcs very freely.
Thank you ... these do not have to be built in some sort of complex command series ... the hot key system works great.
cheers,
eric
6632.16 In reply to 6632.15
Hi eric, I'm glad that setting up the 2 shortcut keys with ArcContinue is close to what you were looking for!
I do want to streamline this process of chaining together different draw tools some more in the future as well. In v4 I hope to spend at least some time on curve tools.
Show messages: All  1-12  13-16
