cplane copy-paste
All  1  2-4
6626.2 In reply to 6626.1
Hi Ditto,
> But when copying the lines to Rhino v4, the cplane doesn't come along. Is
> there a way to copy the cplane over as well?
In Rhino the CPlane is associated with viewports, and when doing copy/paste Rhino will only try to bring over geometry and not any view information so I don't think that there is any way you would bring a cplane into Rhino through pasting.
But you should be able to transfer the cplane I think if you do a full save out from MoI to 3DM format and then use File > Open in Rhino to bring it in, rather than using copy/paste.
6626.3 In reply to 6626.2
Thanks for the explanation. Yes, save-open works fine. Not as fast as I am used to (I actually go a lot back and forth between Rhino and MoI), but that's fine.
I this example, I created a cube, duplicated the edges, threw away the cube, rotated in 3d, adjusted cplane using the script and then project to cplane. Now I have the lines flat on the cplane, and that I can export the DXF for laser engraving.
But the script I have found only gets me close to that, none of the other viewports are identical to the 3d. Any tip?
Thanks a bunch,
Ditto
6626.4 In reply to 6626.3
Hi Ditto,
I'm not sure I understand properly, but do you mean you want to get a 2D result that has perspective in it like you see in the 3D viewport there?
If so you can't use the Project to the cplane to do that - projection on to a plane is a different kind of projection than a perspective projection.
But you can use the DXF output itself to generate that - instead of doing a project to cplane, save a DXF file and in the DXF output set the Projection view option to be "Projection view = 3D", then it will use the same projection you are seeing in the 3D view currently to generate the flattened output to the DXF file.
Show messages: All  1  2-4
