Learning the basics.
 1-7  8-27  28-47  48
6617.28 In reply to 6617.26
Hi David,
> I have to reload my last file as I did several change.
> Here is how I cut my curves, maybe I am overdoing it.
> But with these curves I cannot have a proper shape from network.
Yeah it looks like you've cut them up into too many little pieces there. They need to form a grid layout, but the horizontal and vertical lines of the grid (sort of like lines of longitude and latitude on a globe) need to extend across the entire grid.
There's some more discussion on the type of arrangement that Network needs in some of these previous threads:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4384.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=1778.6
> Here is what I have at the end.
That kind of tip shaping tends to be a consequence of something that's not very uniform collapsing down to a single point.
To reduce it in Network it can be helpful to include a circle or arc curve near the tip so that things are more uniformly spaced just before they collapse down. See a couple of examples of that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3623.14
http://moi3d.com/forum/index.php?webtag=MOI&msg=3550.6
It can be better in general to use more 2D construction though - revolve or rail revolve will tend to form the nicest perfectly round tips on closed objects, then in v3 there are new deformation tools that can be used to deform the smooth revolve onto a different path, see the attached example 3DM file, note here how every curve that went into making the end result was a planar curve that was flat to one of the top/front/right views, not any curves that are warped in 3D themselves. The final result has edge curves that warp in 3D but they're the result of construction from all 2D inputs...
6617.29 In reply to 6617.28
Thanks Michael,
I tested your file and the result with revolve rail is perfect.
One thing I'm not sure to understand is the last step. You did use flow with the blue curve to deform the resulting shape?
What is the purpose of the straight red curve?
But thanks for the tips, I will try to use it.
I'm still trying to build my shapes and that's funny how this method help me to understand better the shape, it will improve my polymodeling at the same time ;)
So here is a shape I'm trying to build.
I tried to apply the different techniques you shown me, but I have some difficutly with this case.
I build the main shape using sweep, and then I wanted to use 2D curves to cut it and produce my final result. But it didn't goes as I planned it.
When I followed my template to draw my curve on the side and cut the shape with it, the projected cut didn't follow my shape in the front view. So I tried to cut an other time in the front, but as you guessed it that didn't worked.
On the pictures I tried to make the curve in 3D and project it on the surface to trim it, but it doesn't resolve the issue.
As I understand it, it is because my volume doesn't intersect at the right place to conform my needs.
The yellow curve is what I want and the purple curve is the result.
How would you approach this?
Edit: I found lyed helmet tutorial thread but the videos are not available, is there an other place to get them as it seems really usefull.
EDITED: 15 Apr 2014 by DMARMOR
6617.30 In reply to 6617.29
Hi David,
The Flow step used both the blue curve and also the red straight curve underneath it. That's how Flow works - it takes in a "base curve" and a "target curve", then remaps points from their relative position on the base curve onto the equivalent relative position on the target curve.
Usually the base curve will be a straight line running like a sort of backbone down the center of the thing you want to deform.
It's tough for me to form a very good comment without being able to examine your actual geometry.
I'm confused as to why the projection does not match your drawn profile in the same 2D view, do you have the cutting curve placed at some kind of inclined angle or something? When you draw a 2D curve to cut with, the resulting cut in 3D should exactly match that same profile in the originating view.
6617.31 In reply to 6617.30
The file is at work so I can't give it to you now, sorry.
About the cut, the issue is not about the projected result from one view. The issue is when I project the drawn curve from the side view if I look through the front view the resulting cut is not matching in this view.
And if I draw the curve in the front view this will be the side view which won't match.
But I think it is completly normal as I'm projecting on a surface. That is my method that doesn't work but I don't have a clue on how to approch this.
I'm trying to make a sci fi helmet, nothing original here ;), but I don't know how to tackle this object.
It's not about tracing already accurate line work, it's about translating a 2D concept to 3D.
I made a sketch in Zbrush and then made a turntable from it, I then used the resulting image as template in MOI to try to reproduce a clean geometry.
Still a lot to learn to be proficient ;)
6617.32 In reply to 6617.31
Hi David,
I guess the usual method is to pick just one of those views, either the front or the side as being the one of primary importance and using that.
If the projection does not result in what you want from another view, that really means that the surface is just not shaped in such a way to make that possible. If that's the case you would need to reconstruct the surface to be better suited for what you want to make.
If I could see the model or maybe know more information about the final end result you're trying to build I might be able to give better advice.
6617.33 In reply to 6617.32
Here is basically the shape I want to build, I made it quickly to illustrate the main problem I have. The bulge on the back and on the side are just here to say that it is not a primary shape and you can't take a sphere and deform it, maybe you can/should?
So my problem is about the cut in front. When I follow the side and trim on my main shape, the front will not follow.
I'm pretty sure that is because of my main shape, and that's the core of my issue, how do you build your main shape to be sure it will fit all your cut in any views. And do you have to tackle this problem like this.
An other thing would be to trace the outline of the shape and build my surface but with that many curve it will produce bulge and imprecise surface.
Sorry for all the newbish question, I still have a lot of homework to do :)
6617.34 In reply to 6617.33
Hi David,
So I guess that normally you would just not go about it in this particular way of trying to control a cut profile from 2 different directions at the same time...
Focus on one cut direction and on how to form the main shape.
It's maybe possible to deform a sphere but it's hard to get very localized features that way. It looks to me like you've still got a primary shape under that outline, notice how there is basically a pattern that starts at the base and continues above the bumps, here I've traced it with red:
Try to ignore the localized bumps and just work on the non-bumped underlying full form. Try to build a base shape that matches that outline first before starting to get into cuts.
6617.35
A quick post to show you what I meant by the cut not having the expected result on each view.
Here I draw my curve from the front and trim on my shape. The cut is as expected on the front but it doesn't match on the side.
Now I made the cut on the side, and the result doesn't match the front =)
I guess it is normal and I have to draw the cut in both view.
But If I move the curve to meet both view we can see that it can't match the shape I built.
So I'm clueless :)
6617.36 In reply to 6617.35
Hi David, you have run into a common problem associated with drawing from prints. 2D flat drawings can''t represent curvature and perspective/parallax. It's a nightmare where the outlines look great until you try to use them and then you find out things don't line up correctly from the different views, so in circumstances like this 'artistic licence' comes into play. You will not succeed in trying to copy this perfectly, you will have to model this on the principle of what it looks like. As long as it is 'close enough' then it should be fine.
The other alternative is to get a picture of a persons head that offers a front and side view. The use something like photoshop or gimp or whatever photo editor software you use. Import your helmet outline for each view then use stretch and scale to make the helmet fit the persons head better, then save them out and then try modelling from them again.
The above theory is great as long as it's a helmet ment for a human head. If it's an alien helmet then you are free to model it according to fantasy rules.
Martin Spencer-Ford
6617.37 In reply to 6617.36
Hi Martin,
Thanks for the explanation, and in fact the way I made my kind of helmet was to test this.
If I had to sculpt this shape I won't have any problem as I'll be able to resolve it while I'm sculpting.
My issue here is how to translate this same process to MOI.
If I trace the cut in 3D space and build my shape from many curves in 3D I'll loose the advantage of using nurbs and I think I will have a blobby result and have a hard time to make it smooth, the very same issue you can have in polymodeling if you have too much edges.
What I have in mind at the moment is how to find a way to buid my shape while still having it to support the cuts.
I have to test this out ;) I wish Lyed helmet tutorial was still available, too bad to see these kind of ressources disappearing because of bad hosting.
6617.38 In reply to 6617.37
Hi David, I'm not really sure what to tell you - it's difficult to control things in the way you're trying to do here with basically trying to reverse engineer how the shape has to be in order to generate the cut you want from the other direction.
Usually with NURBS things are not done in this way, usually there is more of a focus on profiles generating the main shape instead of focusing on the cuts to try and generate the main shape from.
I guess when you don't get the right form from the other direction of your cuts, the deviation there is giving you some information about how you need to manipulate the main shape in order to bring it closer to what you want. So then you probably have to edit the curve at the bottom to make a more tapered shape or something that will come closer to what you want.
I think for your case here it's something like your shape needs to be a lot less sphere like, the widest point needs to be more near the back and it has to taper in a ways at least that's what it seems like...
But it's not very easy to define a shape in this particular way that you're trying to do here...
If you don't really know what shape you want but instead want to derive that shape by incrementally pushing things around, that whole method of point tweaking is more suited for a sub-d or displacement brush sculpting program rather than a NURBS program. The NURBS toolset is more oriented around the concept of you knowing a bit more directly what the base shape should be formed like.
6617.39 In reply to 6617.37
Hi David, so I think in order to get the kind of cut profiles that you want you'd need a shape more like this (also see attached 3DM file):
But this is just not really the way that you'd want to work with things in MoI - you'd want to know before hand that you wanted a shape with a kind of tapering and indentation in it from the beginning rather than trying to start out with a fairly different shape and then try to mutate it to match your end profiles. That's a very sub-d modeling type of process, it's just not what NURBS modeling is really suited for.
I mean it's not like you can't experiment with shapes in MoI, but in a case like you have here it's really a type of organic shape modeling that you're trying to do, with the end result being not a very uniform regularized shape. The more that you get into this type of territory where the thing you want is some kind of result of squashing small zones of the shape around in 3D, the more you leave the territory where NURBS modeling is good at and you go more into the territory where sub-d modeling is good at.
The main difference in these cases is that the profiles you're trying to use do not really fully define the model shape, they're more of a product of some organic shape. It's similar when doing a human face for example - sure a human face has a profile that can be captured at any one particular angle, but that profile alone does not fully define the shape like it does with an extrusion or revolve since the shape changes a whole lot right as you leave that immediate area that the profile happened to capture.
The more the thing you're trying to model fits into that kind of category of "not fundamentally defined by 2D profile curves", the less of a fit that particular thing is for NURBS modeling and the better it fits with sub-d modeling.
6617.40 In reply to 6617.39
Thank you Michael for your patience.
I wrote an answer at work but I certainly made a mistake as I didn't post it.
In substance I was saying that I made the worst shape ever, I did it quickly to illustrate my point but I didn't take into account the final result, just thinking these two views would be enough.
The resulting shape is something close to what you have done and won't produce anything elegant, at least not something I had in mind.
But I will continue to test MOI as I have faith in it =)
I'm sure it can produce fast iteration, at least that's what I want to do. But I have a lot to learn and I have to admit that it is still pleasent to work with it, and it made me improve my subd skills.
I'll do more exercices to see which issue I encounter and how to resolves them.
Thanks for your support.
6617.41 In reply to 6617.40
Hi David,
The basic issue for your case here is that 2 views of an organic shape that has sort of localized lumpy areas and contours to it does not do very much to actually define the shape...
Sub-d or sculpting tools are a better toolset for organic shapes.
NURBS tools really shine with less organic forms where more of the entire shape is defined very well by profile curves, then you are able to use those profiles to directly construct your object and you're all done just using 2D curves only.
Well, there are certainly even worse ones than that! :) But the more sort of blobby and lumpy your end result is the less well defined it becomes from profile curves alone...
It may take you a little while to get the hang of which things work well in MoI and which things you would be better off doing in sub-d modeling instead.
6617.42 In reply to 6617.41
Thanks Michael, I have an other question for you, how do you convert an hard point to a soft point? You know when you construct your curve and you hold ctrl you can make a shape turn, but what if you have this sharp turn in your curve and you want to be soft? At the moment I am creating a new point and delete the old one. Is there any other way to do it?
6617.43 In reply to 6617.42
Hi David,
The way you are already doing it is currently the only way. In the future I want to add in some "point properties" that would allow you to switch a particular point between different modes but that is not set up yet.
6617.44
Hello,
Still there learning ;)
And an other batch of experimentation.
So this time I'm trying to build a simple shape to tackle the basis.
Trying to build it I encounter some issue in the process, here they are.
that's the shape I'm aiming to reproduce:
I created my curves and try to use a blend between two curve but doesn't work. I wanted to use that to manage the curvature with this function instead of having to create the curves with a loft to get the curvature. In the end I prefer to create the curves as I can modify them and see the change in the surface.
I built the shape with a loft using the curves below and then use fillet, the fillet doesn't work. It goes over the top curve and make an awkward shape.
In this one I made a fillet in the curve and add additionnal curves to create the curvature.
I wanted to have a curvature at the front and flat pannel on the side so the curves on the front are bent and straight at the back.
I created the surface using network and sweep but I have the issue circled in red in the shape, it is not smooth, the surface has some visible stepping.
6617.45 In reply to 6617.44
Hi David,
It's difficult for me to give you any suggestions on why it didn't work without any more information - ideally if you could post the 3DM model file with the curves you were trying to blend that would then let me see what you were running into.
Curve blend works by creating a new curve in between the ends of 2 existing curves, note that you have to use it on an open curve if you try to do it between 2 closed curves then it's normal that it would not work because a closed curve does not have an open end on it.
It's a little difficult to say without seeing the actual geometry, but I think that's due to trying to fillet both the upper and lower edge at the same time in a situation where they are coming to a sharp angle to one another.
When you try to fillet 2 edges that come together at a sharp corner area, it's a lot more difficult situation than if they were to touch smoothly, basically the fillet surfaces do not natually align with one another and they will be of different widths where they run into each other. For this particular case where you've got a short of sharply meeting scalloped type shape you would probably be better off filleting the rectangle curves before doing the loft.
Or maybe for your case here it would be better to work on the top piece only by itself first and then work on the bottom part after the top is done.
There were some bugs in v2 that could cause stuff like that as a side effect, there were various improvements and bug fixes to Network in v3 that may have solved this case. Hard for me to say without being able to work with the model file itself though.
6617.46 In reply to 6617.44
Hi David, one possible approach:
Base surfaces built by Loft and some surface control point tweaking:
Surface blend between edges:
Side profile then Trim:
Another profile then sweep 2 rails:
This a sort of alternate "trim and blend" NURBS workflow which can used for stylized objects that may be difficult to create with the usual method of just using boolean cuts on a base shape. This style of NURBS modeling tends to be more complex and has a higher learning curve but it can work for more swoopy industrial design type shapes.
When you're heavily using this style of modeling the advantages of NURBS modeling are not as pronounced (as compared to sub-d modeling) as for things created using more solid modeling operations like booleans. So if your model requires a whole lot of this type of modeling you should possibly think about whether it's really better suited for doing in sub-d instead.
6617.47 In reply to 6617.44
From a "CAD" point of view that's not really a simple shape at all, it would be hard to make a blueprint of it with dimensions on it, there's not any straight lines or things that correspond to constant radius fillets.
The less that a piece has any kind of straight lines in it at all and is all only bendy swoopy stuff, the less of a match it becomes for a CAD toolset, it becomes difficult to drive the design primarily by 2D curves.
NURBS modeling is best suited for models that can be formed by 2D curves - that's when your model will be very quickly and easily created by CAD. If your model is pretty different from that then by CAD standards it's not a simple shape at all and you may be better off doing it in an organic sculpting environment rather than in a CAD environment.
Show messages:  1-7  8-27  28-47  48
