shortcut for enable history
6615.1
hi
Does anyone know how the command should be for enable history of a selected object? Just using "history" just opens the history dialog and "history updateWithHistory" does the same ..
thanks for any hints
nos
6615.2 In reply to 6615.1
Hi nos, this script should enable history updates on the selected objects:
script: /* Enable history updates on selected objects */ moi.geometryDatabase.getSelectedObjects().setProperty( 'updateWithHistory', true );
6615.3 In reply to 6615.2
Hi Michael
I tried to modify it that it would switch the status /true/false instead of just set it to true, but it dosnt work, do you see what Im doing wrong?
script: if ( moi.geometryDatabase.getSelectedObjects().updateWithHistory != 'true' ) { moi.geometryDatabase.getSelectedObjects().setProperty( 'updateWithHistory', true ) } else { moi.geometryDatabase.getSelectedObjects().setProperty( 'updateWithHistory', false ) };
nos
6615.4 In reply to 6615.3
Hi nos, the problem there is: moi.geometryDatabase.getSelectedObjects().updateWithHistory won't work because getSelectedObjects() returns an object list, not just a single object. It's a single object that will have the updateWithHistory property on it, not an object list.
Try this one:
script: /* Toggle history update property on selected objects */ var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length > 0 ) { var val = objs.item(0).updateWithHistory; objs.setProperty( 'updateWithHistory', !val ); }
