Filleting round shapes
All  1-8  9-11
6612.9 In reply to 6612.8
Hi Heiner, did the tuned up version attached above work better for you then?
> and used loft to connect the lower and the upper shape.
I tried repeating this step, and it appears that the loft in its default mode is not making a quite accurate enough fitted result to get it joined properly.
But it does appear to give a good enough result if you set the option in Loft for "Profiles : Exact".
So probably if you delete the side wall parts for the problem letters and build new ones with that "Profiles: Exact" option turned on, it will probably fix it up.
6612.10 In reply to 6612.9
i will give the new version a try, and I will also try that tip with the exact lofting.
I may use some time to do that, because the project now entered a new stage
(preproduction), and I am certain that I will face new tasks very soon.
Best regards
Heiner
(and thanks again for your awesome support!)
6612.11 In reply to 6612.1
Hi Heiner, I was able to track down why there were unjoined edges in your object there when using the default Loft settings - it was due to Loft not using a tight enough fitting tolerance in some cases.
I've got it fixed up for the next v3 beta so that it will be fixed.
Thanks, - Michael
Show messages: All  1-8  9-11
