Filleting round shapes
All  1-5  6-11
6612.6 In reply to 6612.4
OK Michael,
its not that urgent, no problem, have a rest, I am sure you deserve it ;-)
I work with V2 still because i dont like the Updating, deliting, updating etc.
But I will give the latest beta a try and let you know if it solved the problem!
Heiner
6612.7 In reply to 6612.6
Hi Heiner, just want to make sure you didn't miss my 2nd message above where I describe what the problem was with those letters.
6612.8 In reply to 6612.7
I got that answer. If is what you suspect, it was coming out of MOI. What I did is: Made the text and using boleean i ceated the surface of the outside of the text, and by copy and undo went back and created the inside of the letters. Then moved the inside of the letters out (displaced it from the surrounding surface), joined the edges of all letters (inside and outside shapes) and used loft to connect the lower and the upper shape. With that I started my filleting effords. Like I said, I did all that in V.2
Heiner
6612.9 In reply to 6612.8
Hi Heiner, did the tuned up version attached above work better for you then?
I tried repeating this step, and it appears that the loft in its default mode is not making a quite accurate enough fitted result to get it joined properly.
But it does appear to give a good enough result if you set the option in Loft for "Profiles : Exact".
So probably if you delete the side wall parts for the problem letters and build new ones with that "Profiles: Exact" option turned on, it will probably fix it up.
6612.10 In reply to 6612.9
i will give the new version a try, and I will also try that tip with the exact lofting.
I may use some time to do that, because the project now entered a new stage
(preproduction), and I am certain that I will face new tasks very soon.
Best regards
Heiner
(and thanks again for your awesome support!)
6612.11 In reply to 6612.1
Hi Heiner, I was able to track down why there were unjoined edges in your object there when using the default Loft settings - it was due to Loft not using a tight enough fitting tolerance in some cases.
I've got it fixed up for the next v3 beta so that it will be fixed.
Thanks, - Michael
Show messages: All  1-5  6-11
