Offset curve on surface?
All  1-6  7-8
6602.7 In reply to 6602.6
In your case just make a Sweep with 2 rails!
So you will sure that your profil follows external and internal curves!
EDITED: 4 Apr 2014 by PILOU
6602.8 In reply to 6602.6
Hi Paulo,
> You can see in the other images that the profile isn't matching the cylinder everywhere.
> Should I do it more "precise" in the sweep options??
There isn't any way for a one-rail sweep to keep the profile to be "stuck down" on a bendy surface like it looks like you're trying to do.
Probably your best bet is a 2 rail sweep like Pilou writes, with 2 rail curves running down either side of the profile rather than only one rail down the middle of it.
If you're still having problems can you please post the 3DM model file with your objects in it, that tends to help a lot to be able to work with your actual geometry to answer questions.
Show messages: All  1-6  7-8
