My shortcut keys have desappeared.
All  1-2  3-7
6601.3 In reply to 6601.1
Hi Gaston, yes like Danny write above the shortcut key definitions are stored in moi.ini so you'll want to copy that file over into the new Windows installation's equivalent spot in order for those settings to come over.
If you did an "in place" upgrade from XP to Win7, it looks like your old AppData folder might be available under a c:\Windows.old directory, so check if you can find a file under something like: c:\Windows.old\Users\<username>\Application Data\Moi\moi.ini
and then copy that moi.ini file over to C:\Users\<username>\AppData\Roaming\Moi\moi.ini - you'll have a new one in place there since if it's not found it will create a new one when you first ran the new beta. Overwrite that newly created one with your previous one from XP and then you should get your shortcut keys back again.
6601.4 In reply to 6601.2
Hi Danny,
Bingo :)
I replaced the new moi.ini file with the previous beta one.
I just hope that I didn't break anything in the new beta by simply replacing its moi.ini.
Gaston
6601.5 In reply to 6601.3
Good to know. In this case I have installed windows 7 on a separate disk so everything was left unaltered.
Gaston
6601.6 In reply to 6601.4
Hi Gaston,
Nope, that won't break anything, it should be fine to do that.
6601.7 In reply to 6601.6
Oh but make sure you have closed MoI before you do any .ini file copying around.
Show messages: All  1-2  3-7
