Fusing Laser Printing to Powder Coated Aluminum
I thought this was a very cool. PDF output from MoI can be laser printed, even in color, and then fused with a
laminator to powder coated aluminum. I think Home Depot has the aluminum in the roofing department.
The Mirror command will reverse text.
This came from:
http://email.villagepress.com/pub/HSM/20140402/20140402.html
Their link: http://rick.sparber.org/LPPC.pdf
I've got a laminator around here somewhere.
EDITED: 2 Apr 2014 by BEMFARMER
6600.2
Wow Bem, I could have used that trick on my home made radio:
MoI would be perfect for accurate dial ticks.
I wonder if the same trick would work on spray paint?
I would also suggest adding a clear fixative over the laser transfer.
6600.3 In reply to 6600.1
Looks like a really cool technique! If you try it please post pics of the results!
6600.4 In reply to 6600.1
For transferring engraving designs to metal I use a laser print on plain paper, acetone, and a bit of burnishing. It works very well, though the technique described may be superior.
