Hi Max,
> As title says - Looks like that option in the ini file is not working
> anymore? I usually set it to N. Any ideas?
I gave it a quick test and it seems to be working for me over here.
Try this - draw a circle and set it to style = red, then extrude it.
The style of the generated extrusion is different depending on the setting:
[Styles]
GeneratedObjectsInheritStyle=y
With =y the extrusion gets style of red copied from its generator curve. With =n the extrusion gets the "current style" applied to it instead of the generator curve's style.
If something is not behaving as expected for you could you describe what is happening in more detail and maybe post a sample file so I could try to reproduce the problem over here?
