Importing a polygon model as a component of a MoI model
6586.1
Ok, so I Love MoI. It's amazing. Though I work at a place that has Solidworks and Rhino seats, I prefer MoI as it is just a faster and more intuitive drafting tool.
However, it has one major downfall that I'm hoping there is a solution to. I occasionally export my models into ZBrush to give them a bit of surface detail such as texturing, and I then create obj files or stl files out of them as I can't reconvert to Nurbs.
But let's say I just want a zbrush-edited stl object to be one component out of a larger model with more pieces, is there a way I can import it into MoI and just have it as a floating element? I don't need editability above and beyond translation tools. Essentially, it would be a floating, uneditable piece that would merely sit among other nurbs-created models. the facility exists in solidworks, I just wondered whether it could exist in MoI without my knowledge.
all the best,
rob.
EDITED: 26 Mar 2014 by ZEROBMEISTER
6586.2 In reply to 6586.1
No can do at the moment, but only because MoI won't import polygon mesh data files, but It would be great if it would import them as an always locked object
Martin Spencer-Ford
6586.3 In reply to 6586.1
Hi rob,
Sorry no there isn't currently any way to do mesh component import into MoI like you're describing... That is something that I'd like to maybe figure out in the future but it's a difficult area to do without leading to various types of confusion for people who don't know that those elements are different than other ones that you have drawn directly in MoI and why the imported file does no interact with their drawn objects.
Right now to eliminate that entire category of confusion I have not pursued doing those types of imports for now.
A lot of people move the whole project over to a polygon modeling program once you have one piece of it that has become polygonal data.
6586.4 In reply to 6586.3
Thanks for the detailed reply Michael.
I hope you do consider incorporating an STL import function, I'm sure those who get confused by the polygon/ NURBS differentiation will be able to work out why booleans aren't working on their STL import ;)
rob.
6586.5 In reply to 6586.4
Hi Rob,
Well I know for sure from my previous experience developing and supporting Rhino that a lot of people will not be able to work that out, it's an easy thing to get confused about.
I think the confusion may be reduced if I can figure out a good auxiliary place to put the import, like under some kind of "reference geometry" section or something other than the regular file import... I'm not sure where that would be yet though.
