New Variable Fillet Radius
All  1  2-18
6584.2
I used the new variable radius fillet and it is awesome very robust, in my opinion, for first release of this feature, you asked me a question in 2008 http://moi3d.com/forum/index.php?webtag=MOI&msg=1703.5 and one of the things I said was I missed variable filleting and now it's here :) I actually pulled up that model in that thread and tried it out.....beautiful.
Just one thing that would be good if possible is the ability to delete a fillet set whilst in the command.
Hope you and your family are having a great time on your well deserved vacation.
6584.3 In reply to 6584.2
Good idea Danny, I'll take a look at what's involved with that when I get back.
Right now I'm one island over from Burr!
6584.4
You lucky!
Well deserved Michael!
Enjoy the vaca, and don't let any red-headed Pupule birds get you.
6584.5 In reply to 6584.3
""""Right now I'm one island over from Burr!""""
I used to live on one of those. The other is one of the "40 years behind" islands, but has one of the most beautiful valleys to get away to.....
If your where I think you are, you must get to the west end. That's where you'll meet MoI! (You have to find someone who can direct you to the cane roads to drive to the very end)
Enjoy!
6584.6 In reply to 6584.5
Hi Burr, I'm over on Maui, I thought you were on the big island?
6584.7 In reply to 6584.6
I'm on Oahu. The city one. I've only been to Maui a couple times. East side hotel stuff and west side coastal hiking..... :)
6584.8 In reply to 6584.7
Hi Burr, someday we'd like to head over to Oahu too!
6584.9 In reply to 6584.8
Be sure to let me know. I'd like to meet for some carrots or something!
6584.10
Hi All :)
Thanks for the new beta Michael :)
Having a play with Variable Fillet Radius
I added some red points to a edge on the 2 objects , starting with the edge on the top object, I applied a fillet (5) then added a fillet set(2.5), placing the fillet points on the red points , first the right hand point then the left one. and it worked has expected...:) on the closed edge of the cylinder I'm guessing it does not know which part of the closed edge is between the points ....?
6584.11 In reply to 6584.10
Hi Steve - on your cylinder you show there, it looks like it's working, it just appears that you do not have very much space from the point back to the start of the closed edge so it's having to grow from 2.5 to 5 in a small distance on one side...
Basically your point spacing on the cylidner case looks like one of the points is pretty close to the end of the edge (where the radius will be 5) so that makes it somewhat different in proportion to the straight one.
Maybe if you are seeing something wrong there you could give a more detailed explanation of what you were expecting?
6584.12 In reply to 6584.11
Hi Michael
The screen shot is not the best. the larger fillet you can see on the right does not extend around the back to the left side . don't worry about it, I'm sure its just me. I do some more testing :)
so far the new release seems faster on OSX. :)
Cheers, Stephen
6584.13 In reply to 6584.12
Hi Stephen,
But isn't it a closed fillet surface that starts and ends with the large radius size?
Good! There was a problem with previous releases with files getting stored in ~/Library/Saved Application State/ for every program launch and once those accumulated to a large number it could kind of gunk up the OSX program launcher mechanism. This beta should not generate any more of those and will clear out old ones which should get rid of one category of slow startup problems.
6584.14 In reply to 6584.13
>Hi Stephen,
Yes but the small radius extends past the left hand point and nearly goes all the way around to the end. , I delete the file :( , I will try again when I get home tonight. :)
Cheers, Stephen
6584.15 In reply to 6584.14
Hi Stephen,
Well yeah, it gradually increases until the end, if it wasn't a gradual increase it would not end up with the same radius at the start and end point...
6584.16
Just wondering if you were considering this http://moi3d.com/forum/index.php?webtag=MOI&msg=6584.2
6584.17 In reply to 6584.16
Hi Danny,
It's on my list to investigate... Pretty soon here I've got to wrap things up for V3 though.
6584.18 In reply to 6584.17
You do what you have to do, it's your baby :) as I said I was just wondering.
Show messages: All  1  2-18
