Trim to Create 2D Shape
All  1  2-4
6583.2
Geez, why could I not get the MoI trim tool to work until I posted this question? I seem to have it figured out now.
_________________________
Don Cheke
Visit: Textual Creations
Maybe select all / Boolean Union gives the good result in some cases ?
6583.4 In reply to 6583.2
Hi Don, it sounds like you've got it handled now but in MoI that's called a "mutual trim" where you want each object not just to get cut but to also cut others in the same operation as well.
To do a mutual trim, you just select all the things you want to trim, and when Trim prompts you to select cutting objects you push "Done" or right-click at that point to signal that you are not selecting other cutting objects and instead doing mutual trim.
Show messages: All  1  2-4
