Hi Fabien, yeah I can repeat the distortion when using G1 blend - maybe the blend variants are not expecting to see a zero radius and get kind of freaked out when they run into one. That might not be difficult to tune up (famous last words...), I'll take a look when I get back from vacation.
In the meantime if you want a conical result you'll only get that with circular anyway though.
And re: linear blend - you generally don't want to leave that on when you're filleting any sort of chain of edges, because you'll get an abrupt change of shape where 2 fillets run into each other.
So wineskin has been the culprit with performance on my mac. Actually, I'm still using v2.52. Have most of you been using the beta? Perhaps I should give it try (now that I've finally got the interface to match my favorite Vim color scheme).
Maybe you must keep previous version, because generally you will have installed some special scripts or commands!
So an easy way for make some copy past!
Is beautiful that please without concept! My Gallery
> Anyone experiencing long start times with the new beta?
> Should I have deleted the old beta before loading this one?
No you don't need to delete the old beta before loading the new one, and in fact I'd recommend keeping the old one around just in case there's something wrong with the new one.
Are you on PC or Mac? Do our long start times persist after the first initial load? What happens if you restart your machine does that change anything?
> Excellent performance improvements on the hidden line removal.
> I'm down to just a few minutes to do minor cleanups on large
> images, thanks Michael.
That's great OSTexo, I'm glad that it's useful for you!
How much time was it generally taking you before, maybe a fair amount of time for some cases?
