V3 beta Mar-24-2014 available now  1-20  21-34
A new v3 beta (version Mar-24-2014) is now available for download here: http://moi3d.com/beta.htm , also linked to from the download page on the main web site.
I think this will probably be the 2nd to last beta for v3, I'm expecting to do one more with just a couple of remaining things.
New stuff:
Variable radius fillets - you can now define different radius values at particular points, using the "New point set" button as shown here:
New "Add sync points" option for Blend which lets you add in points to tell Blend which parts of the edges to connect together, overriding the default which just connects them by distance traveled along the curve.
Lots of tuneups for hidden line generation:
Update hidden line generation accuracy. Improve accuracy of hidden line results by performing curve/curve intersections when visibility changes, to align the transition point accurately to other geometry. Since it can use only local operations slowdown is only about 4%. Accuracy of the generated result is greatly improved.
Update hidden line generation for DXF output and Make2D - don't refit rationals (like circles and ellipses) as cubics for DXF or Make2D output since unlike AI/PDF format these can handle full rational bspline output. Previously all hidden line generation was refitting cubic curves to the hidden line output.
Calculate depth bias tolerance by relative tolerance factor using overall bounding box size. Helps with problems with poor visibility results on larger or smaller sized scenes.
Fix bug with incorrect bounds gathering for standalone curves.
Fix bug where clip planes were not necessarily being set in the renderview to encompass the geometry being rendered. This could lead to unwanted near/far clipping happening when scripting PDF/AI export. Fixes a bug reported through e-mail by Jeff Dierstein
Improve out of memory handling in hidden line generation, show "Insufficient memory" warning instead of just crashing like it previously did.
If an edge curve is hidden, don't use it in the hidden line calculation. And if a face is hidden don't generate shaded output or silhouettes for it.
Backfacing silhouette detection. Improvements in backfacing detection at concave silhouette areas, Helps to reduce "hook" type overshooting visible curve areas at bases of cylidner protrusions and similar features.
Some fillet fixes separate from variable radius fillets:
Updated fillets to fix problems with fillets occasionally splitting into 2 long strips down their centerlines.
Update fillet command - Allow 0 radius to be entered as a way to reset the fillet and restore the original object for preview.
Fixed a bug with periodic fillets reported on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6297.35
Other fixes:
Fixed a bug with viewport flickering when loading a 3DM file by double-clicking
it in Explorer when the 3DM file had a single maximized view in it, under
certain timing conditions. Fixes a bug reported a while ago by Steph3D and on the forum more recently by milkywaif and Colin.
Update extrude sorting tolerance Adjust coplanarity tolerance for curve cluster sorting, fixes a bug where curves that were only a teeny tiny bit different in elevation would not be extruded together, reported on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6567.1
Update deformations to allow attributes like style and names on faces and edges to persist. Fixes a bug reported on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6538.3
Update sweep mitering for near tangent cases. Fixes a regression in v3 in sweep mitering reported on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6529.1
Update osx version - Update wineskin mechanism to avoid accumulating a bunch of directories under ~/Library/Saved Application State/12345.wineskin.prefs.savedState When these grew too numerous startup time could slow down a lot, or even prevent MoI from being launched at all. This version will also automatically clear out any old wineskin.prefs.savedState files accumulated from previous versions and should not make new ones anymore.
Update projected intersection object snap - Cancel projected intersection solver calculation if it takes more than 500ms. Fixes problems reported with object snap freezing while picking points looking down on a helix.
Add Portuguese UI strings from Duarte Ramos
Update curve/curve flow to avoid problems with unwanted rotations on the target curve - should fix problems with curve to curve flow with the curves positioned in the Front view instead of the Top view for example.
Update history - fix file size bloating problem related to history reported in the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6426.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6412.1
Update Silhouette command - fix logic for determining silhouette edges, fixes a bug reported through e-mail by James Elliott.
Update straight sections loft - Fix bug with straight sections loft, reported on the forum here (regression from v2):
http://moi3d.com/forum/index.php?webtag=MOI&msg=6431.1
Fix excessive memory consumption for PlanarSrf reported on the forum here:
Update moi.filesystem.openFileStream() - Update readLine method on a file stream to work with any length line, previously it was limited to only read lines up to 1023 characters in length.
Update perspective field of view UI - Fix bug where the perspective FOV property for scripting was using an incorrect conversion process, this made a wrong value used under Options > View > 3D View angles > Field of view. The wrong value was generally close enough to the right value to kind of make it look like it was working. The fixed version should allow for better camera matching for matching MoI generated 2D output to other renderers.
Updated AI clipboard support for older version Illustrator compatibility on OSX. For doing a copy to clipboard using AI format on Mac, use the following for going into an older version of Illustrator like CS3 or earlier:
script: moi.geometryDatabase.copyToClipboardAI( 'UseAICB=true' );
Fixed a bug with AI format export, the bug was a garbled %%HiResBoundingBox entry in the AI header section, it was messing up pasting into Photoshop. Reported on the forum here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6201.269
Fixed a bug with rail revolve on non-planar paths reported on the forum here:
…[Message Truncated]
View full message.
EDITED: 25 Mar 2014 by MICHAEL GIBSON
6579.2 In reply to 6579.1
First! :p Thanks Michael, have a good well deserved vacation
M.
6579.3 In reply to 6579.1
Cheers Michael! Looks sweet will try soon.
6579.4
The new Variable Radius options are great! Would be nice to be able to set a point to a radius of 0.00. When used with the linear option, it would provide a conical fillet, for example from one corner to the opposite of a cube. Currently the fillet is distorted unless a radius of > 0.00 is provided (0.01 works).
UPDATE: this fine works for circular fillets, I was using G1 with the example above.
Have a great vacation Michael!
I've got the release notes updated now.
6579.6 In reply to 6579.4
Hi Fabien, yeah I can repeat the distortion when using G1 blend - maybe the blend variants are not expecting to see a zero radius and get kind of freaked out when they run into one. That might not be difficult to tune up (famous last words...), I'll take a look when I get back from vacation.
In the meantime if you want a conical result you'll only get that with circular anyway though.
6579.7 In reply to 6579.4
And re: linear blend - you generally don't want to leave that on when you're filleting any sort of chain of edges, because you'll get an abrupt change of shape where 2 fillets run into each other.
6579.8
That's a good healthy update Michael - Thanks, enjoy your vacation
Martin Spencer-Ford
Cool news!
You will have the French version in no time! :)
6579.10 In reply to 6579.1
Cool... cheers Michael...
Peace,
Rich_Art. ;-)
6579.12
Thank you Michael. Nice update.
- Evren
6579.13
Michael... Thank you so very, very much!
YOU ARE THE MAN!!!!
I'll sneak in some time today to try these out more, but from what I can see so far, I'm really excited about your new tweaks!
Have a wonderful, well-deserved vacation!
6579.14
Wow, someone has been busy : )
So wineskin has been the culprit with performance on my mac. Actually, I'm still using v2.52. Have most of you been using the beta? Perhaps I should give it try (now that I've finally got the interface to match my favorite Vim color scheme).
6579.15
Variable fillets are da bomb! :-)
Looks great. Thanks, Michael.
6579.16
Results of Make2D are better now. Thank you!
6579.17
Anyone experiencing long start times with the new beta?
Should I have deleted the old beta before loading this one?
Ron
6579.18 In reply to 6579.17
Maybe you must keep previous version, because generally you will have installed some special scripts or commands!
So an easy way for make some copy past!
6579.19 In reply to 6579.17
Hi Ron,
No you don't need to delete the old beta before loading the new one, and in fact I'd recommend keeping the old one around just in case there's something wrong with the new one.
Are you on PC or Mac? Do our long start times persist after the first initial load? What happens if you restart your machine does that change anything?
Thanks, - Michael
6579.20 In reply to 6579.19
Right on Michael. Righteous release!
Show messages:  1-20  21-34
