Got stuck in trying to create a loop wheel....
All  1-8  9-13
6577.9 In reply to 6577.1
Hi Yves,
Another method would be to created the two red surfaces (Extrude) and the green surface on the diameter, I used revolve at 40°, this would be where the clamp sits, then use blend (Curvature G2) between the end of the red surface and the end of the green surface this way you can dynamically adjust the bulge, I used 2.25, join all and apply a thickness.
Does this bicycle is bouncing ?
6577.11 In reply to 6577.10
Shock absorbing spring design instead of spokes :P
Martin Spencer-Ford
6577.12
A BIG thank you to all the forum members for taking the time to formulate a response. I was able to create what I need by using Shane's method where you use 3 profiles to force the shape to stay square.
Since there seem to be a number of different ways to achieve the same goal, I'm going to continue to experiment with some of the other methods.
@ Danny: I am definitely going to take a look at your method. This also looks promising.
@ Pilou: the fiber springs in the wheels provide suspension. I'm especially interested in these wheels because I ride a Raptobike low racer recumbent (see picture). The small front wheel is uncomfortable on the bumpy Belgian roads. The specific layout of the bike does not allow any other form of suspension.
Size: 113.3 KB, Downloaded: 25 times, Dimensions: 1353x626px
6577.13 In reply to 6577.12
Very ingenious to put suspensions inside wheels!
The famous "Pavés du Nord" of Paris-Roubaix! ;)
Show messages: All  1-8  9-13
