lost in drawing 3d
All  1-6  7-12
6576.7 In reply to 6576.5
That is amazing. thanks. that is perfect. I will see If I can repeat that. I have attached what I have come up with, but I like yours better.
The "side Node" is a hook eyelet which I will draw separate and add to my drawing later. I draw all of my hooks in MOI and can do that pretty easy.
These shapes that you have helped me with is what gives me the most trouble, but what you have done looks easy. thanks!
David
www.hooksolutions.com
6576.8 In reply to 6576.7
Hi David, yeah it tends to be difficult to do something like this in a little "piece by piece" way, it's just easier to get a smooth continuous looking form if you build it as one bigger thing. But that's just for the main body shape, things that stick out should be separate pieces booleaned on.
Another way you can approach a shape that is not very symmetrical and kind of organic is by drawing in several parallel plane curves and then using Construct > Loft with the "loose" option. For a closed spot, there is a new feature in v3 loft where you can put in a point object to close the end of the loft off smoothly, here are some things that show that way:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6082.10
http://moi3d.com/forum/index.php?webtag=MOI&msg=6082.8
Also there are some demo videos from Andrei on this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.1
The main thing that's different with that method though is that you are primarily controlling the shape through the cross sections, you have to adjust those to get the kind of profile you want while using sweep lets you draw in the side profile more directly.
But if you have a fairly difficult smooth shape, the organic loft method can sort of give you the most detailed control over it.
6576.9 In reply to 6576.6
ok, that's neat. I can use that in some other applications.
I was able to reproduce your first example. thanks again!
David
6576.10 In reply to 6576.9
You're welcome David!
6576.11
OK I'm a pretty slow modeler...
By now you've made the jig, caught the fish, cleaned & eaten it.. :)
But here's what I set up.
Sweep, pick profile #1
Select rail 2 & 3
Select scaling rail #4
3dm file attached...
6576.12 In reply to 6576.11
thanks! that works good too. I appreciate that.
David
Show messages: All  1-6  7-12
